xTour and tour points fixation
Posted: Mon Nov 28, 2016 2:40 pm
Here is the description of my issue with xTour and tour point fixation :
I have two basic input tours with one tour point in each of them. See below their skeleton :
Input Plan
T1 : D – TP1 – D
T2 : D – TP2 – D
I set on the TP1 and TP2 the attributes tourFixed and remainPlanned to true
I’m expecting to get back in the output plan the same two tours because I fixed them.
But xTour returns one single tour with the merge of the two input tours.
Do I miss something ? ( the use case is voluntary reduced to two orders for the convenience of the explanation)
If I add the fixation of the vehicle (attribute vehicleFixed) on each of the input tour then I get the expected result.
I don't know why, I can't upload a file
I put the request here:
and the response:
best regards,
François
Input Plan
T1 : D – TP1 – D
T2 : D – TP2 – D
<SOAP-ENV:Header xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/"/>
<soap:Body>
<planBasicTours xmlns="http://types.xtour.xserver.ptvag.com" xmlns:ns2="http://xtour.xserver.ptvag.com" xmlns:ns3="http://wrappertypes.service.jabba.ptvag.com" xmlns:ns4="http://common.xserver.ptvag.com" xmlns:ns5="http://baseservices.service.jabba.ptvag.com" xmlns:ns6="http://xmap.xserver.ptvag.com" xmlns:ns7="http://exception.core.jabba.ptvag.com">
<ArrayOfTransportOrder_1>
<ns2:TransportOrder xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" id="3464" priority="1" trailerLoadingForbidden="false" xsi:type="ns2:TransportDepot">
<ns2:maxLoadingArea xsi:nil="true"/>
<ns2:minLoadingArea xsi:nil="true"/>
<ns2:wrappedVehicleCategories xsi:nil="true"/>
<ns2:wrappedVehicleExclusions xsi:nil="true"/>
<ns2:wrappedVehicleRequirements>
<ns3:Int>4</ns3:Int>
<ns3:Int>478</ns3:Int>
</ns2:wrappedVehicleRequirements>
<ns2:deliveryQuantities>
<ns2:wrappedQuantities>
<ns3:Int>1080</ns3:Int>
</ns2:wrappedQuantities>
</ns2:deliveryQuantities>
<ns2:wrappedDepotIds xsi:nil="true"/>
<ns2:pickupQuantities xsi:nil="true"/>
<ns2:transportPoint allowServiceSplit="false" coDriverRequired="false" id="3464" openingIntervalConstraint="COMPLETE_SERVICE" servicePeriod="900" tourSection="0" useServicePeriodForRecreation="false">
<ns2:location>
<ns4:kml xsi:nil="true"/>
<ns4:point x="6.1642" y="49.21532"/>
</ns2:location>
<ns2:wrappedOpeningIntervals>
<ns2:Interval from="28800" till="61200"/>
</ns2:wrappedOpeningIntervals>
</ns2:transportPoint>
</ns2:TransportOrder>
<ns2:TransportOrder xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" id="3465" priority="1" trailerLoadingForbidden="false" xsi:type="ns2:TransportDepot">
<ns2:transportPoint allowServiceSplit="false" coDriverRequired="false" id="3465" openingIntervalConstraint="COMPLETE_SERVICE" servicePeriod="900" tourSection="0" useServicePeriodForRecreation="false">
<ns2:location>
<ns4:point x="6.16392" y="49.21661"/>
</ns2:location>
</ArrayOfTransportOrder_1>
<ArrayOfDepot_2>
<ns2:Depot id="123">
<ns2:location>
<ns4:kml xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true"/>
<ns4:point x="6.1637" y="49.20272"/>
</ns2:location>
<ns2:wrappedOpeningIntervals xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true"/>
</ns2:Depot>
</ArrayOfDepot_2>
<Fleet_3>
<ns2:wrappedTrailers xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true"/>
<ns2:wrappedTrains xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true"/>
<ns2:wrappedVehicles>
<ns2:Vehicle departureTimeFixed="28800" depotIdEnd="123" depotIdStart="123" dimaId="2" drivingPeriodFactor="1.0" id="1" ignoreIntermediatePeriodBeforeFirstTour="false" ignoreTransportPointServicePeriod="false" isPreloaded="false" servicePeriodFactor="1.0" toursMustFitIntoSingleOperatingInterval="false">
<ns2:wrappedOperatingIntervals>
<ns2:Interval from="28800" till="43200"/>
</ns2:wrappedOperatingIntervals>
<ns2:capacities>
<ns2:wrappedCapacities>
<ns2:Quantities>
<ns3:Int>14400</ns3:Int>
</ns2:Quantities>
</ns2:wrappedCapacities>
</ns2:capacities>
<ns2:costs xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true"/>
<ns2:driverSettings breakRuleActive="false" dailyRestRuleActive="false" regulationsId="1" weeklyRestRuleActive="false" workingRuleActive="false">
<ns2:maximumTourPeriodRestriction xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true"/>
</ns2:driverSettings>
<ns2:wrappedAreaNumbers xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true"/>
<ns2:endLocation xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true"/>
<ns2:maxLoadingArea xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true"/>
<ns2:minLoadingArea xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true"/>
<ns2:restrictions maxTourCountPerChain="1"/>
<ns2:startLocation xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true"/>
<ns2:wrappedTransportEquipments>
<ns3:Int>21</ns3:Int>
<ns3:Int>10</ns3:Int>
<ns3:Int>9</ns3:Int>
<ns3:Int>20</ns3:Int>
<ns3:Int>3</ns3:Int>
<ns3:Int>8</ns3:Int>
<ns3:Int>25</ns3:Int>
<ns3:Int>16</ns3:Int>
<ns3:Int>24</ns3:Int>
<ns3:Int>14</ns3:Int>
<ns3:Int>12</ns3:Int>
<ns3:Int>22</ns3:Int>
<ns3:Int>5</ns3:Int>
<ns3:Int>18</ns3:Int>
<ns3:Int>11</ns3:Int>
<ns3:Int>7</ns3:Int>
<ns3:Int>15</ns3:Int>
<ns3:Int>17</ns3:Int>
<ns3:Int>2</ns3:Int>
<ns3:Int>6</ns3:Int>
<ns3:Int>19</ns3:Int>
<ns3:Int>23</ns3:Int>
<ns3:Int>13</ns3:Int>
<ns3:Int>1</ns3:Int>
<ns3:Int>384</ns3:Int>
<ns3:Int>378</ns3:Int>
<ns3:Int>377</ns3:Int>
<ns3:Int>379</ns3:Int>
<ns3:Int>372</ns3:Int>
<ns3:Int>382</ns3:Int>
<ns3:Int>368</ns3:Int>
<ns3:Int>369</ns3:Int>
<ns3:Int>383</ns3:Int>
<ns3:Int>380</ns3:Int>
<ns3:Int>370</ns3:Int>
</ns2:wrappedTransportEquipments>
</ns2:Vehicle>
<ns2:Vehicle departureTimeFixed="28800" depotIdEnd="123" depotIdStart="123" dimaId="2" drivingPeriodFactor="1.0" id="25" ignoreIntermediatePeriodBeforeFirstTour="false" ignoreTransportPointServicePeriod="false" isPreloaded="false" servicePeriodFactor="1.0" toursMustFitIntoSingleOperatingInterval="false">
<ns2:capacities>
<ns2:Quantities>
</ns2:Quantities>
</ns2:capacities>
<ns3:Int>472</ns3:Int>
<ns3:Int>486</ns3:Int>
<ns3:Int>470</ns3:Int>
<ns3:Int>493</ns3:Int>
<ns3:Int>409</ns3:Int>
<ns3:Int>408</ns3:Int>
<ns3:Int>481</ns3:Int>
<ns3:Int>476</ns3:Int>
<ns3:Int>504</ns3:Int>
<ns3:Int>463</ns3:Int>
<ns3:Int>491</ns3:Int>
<ns3:Int>458</ns3:Int>
<ns3:Int>506</ns3:Int>
<ns3:Int>414</ns3:Int>
<ns3:Int>422</ns3:Int>
<ns3:Int>498</ns3:Int>
<ns3:Int>492</ns3:Int>
</ns2:Vehicle>
</ns2:wrappedVehicles>
</Fleet_3>
<PlanningParams_4 xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" availableMachineTime="120" coDriverTransportPointsInSeparateTours="false" constructionStep="true" endSequencingStep="true" improvementStep="true" middleSequencingStep="true" sequencingMethod="cSMThoroughOpt" startSequencingStep="true" tourReductionStep="false" xsi:type="ns2:StandardParams">
<ns2:wrappedDistanceMatrixCalculation>
<ns2:DistanceMatrixCalculation deleteAfterUsage="true" deleteBeforeUsage="true" dimaId="2" xsi:type="ns2:DistanceMatrixByRoad"/>
</ns2:wrappedDistanceMatrixCalculation>
<ns2:wrappedLoadingFunctions xsi:nil="true"/>
<ns2:wrappedProductIncompatibilities xsi:nil="true"/>
<ns2:wrappedRegulations>
<ns2:RegulationsBase beginningOfCalendarWeek="0" id="1" xsi:type="ns2:DriverRegulations">
<ns2:breakIntervals breakPeriod="0">
<ns2:wrappedIntervals>
<ns2:Interval from="0" till="0"/>
</ns2:wrappedIntervals>
</ns2:breakIntervals>
<ns2:breakRule xsi:nil="true"/>
<ns2:dailyRestRule xsi:nil="true"/>
<ns2:weeklyRestRule xsi:nil="true"/>
<ns2:workingRule xsi:nil="true"/>
</ns2:RegulationsBase>
</ns2:wrappedRegulations>
<ns2:restrictions>
<ns2:tourRestrictions maxDistance="500000" maxDistanceBetweenTransportPoints="7000"/>
</ns2:restrictions>
<ns2:goalImportance chainPeriodRank="0" tourCountRank="0" tourDistanceRank="3" tourDrivingPeriodRank="0" tourPeriodRank="0" unplannedOrdersRank="0" vehicleCountRank="1"/>
</PlanningParams_4>
<Plan_5>
<ns2:wrappedChains>
<ns2:Chain vehicleId="1">
<ns2:result xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true"/>
<ns2:wrappedTours>
<ns2:Tour id="370" ignoreIntermediatePeriodOfPreviousTour="false" startTimeFixed="false" vehicleFixed="false">
<ns2:restrictions xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true"/>
<ns2:wrappedTourPoints>
<ns2:TourPoint id="123" remainPlanned="false" tourFixed="false" type="DEPOT">
</ns2:TourPoint>
<ns2:TourPoint id="3464" remainPlanned="true" tourFixed="true" type="TRANSPORT_POINT">
</ns2:TourPoint>
</ns2:TourPoint>
</ns2:wrappedTourPoints>
</ns2:Tour>
</ns2:wrappedTours>
</ns2:Chain>
<ns2:Chain vehicleId="25">
<ns2:wrappedTours>
<ns2:Tour id="371" ignoreIntermediatePeriodOfPreviousTour="false" startTimeFixed="false" vehicleFixed="false">
</ns2:TourPoint>
<ns2:TourPoint id="3465" remainPlanned="true" tourFixed="true" type="TRANSPORT_POINT">
</ns2:TourPoint>
</ns2:TourPoint>
</ns2:Tour>
</ns2:wrappedTours>
</ns2:Chain>
</ns2:wrappedChains>
</Plan_5>
<CallerContext_6>
<ns5:wrappedProperties>
<ns5:CallerContextProperty key="CoordFormat" value="OG_GEODECIMAL"/>
<ns5:CallerContextProperty key="TenantId" value="68d9ee7e-b551-11e6-b3a3-ecf4bb142308"/>
<ns5:CallerContextProperty key="Profile" value="V-ESSENCE-WO-TOLLROADS"/>
</ns5:wrappedProperties>
</CallerContext_6>
</planBasicTours>
</soap:Body>
</soap:Envelope>
and the response:
<?xml version="1.0" encoding="UTF-8"?><soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/">
<soap:Body>
<ns3:planBasicToursResponse xmlns:ns6="http://exception.core.jabba.ptvag.com" xmlns:ns2="http://baseservices.service.jabba.ptvag.com" xmlns:ns1="http://common.xserver.ptvag.com" xmlns:ns3="http://types.xtour.xserver.ptvag.com" xmlns:ns0="http://wrappertypes.service.jabba.ptvag.com" xmlns:ns4="http://xtour.xserver.ptvag.com">
<ns3:result>
<ns4:wrappedChains>
<ns4:Chain vehicleId="25">
<ns4:result distanceToEndLocation="0" periodToEndLocation="0" distanceFromStartLocation="0" periodFromStartLocation="0" endTime="31282" drivingPeriod="682" remainingPeriods="22 serialization::archive 9 0 2 0 0 1 4 0 4 0 0 0 0 16200 0 0 0 1 0 39600 0 28800 0 0 3 2147483647 2147483647 2147483647 0 0 0 0 0 1 0 0 0 28800 0 0 28800 0 0 633600 0 0 6 0 0 0 28800 0 0 0 0 0 0 0 0 0 3 0 0 31282 2147483647 0 31282 0 0 0 4 0 0 0 0 0 0 0 2 0 0 2 0 0 0 0 0 4 0 0 0 0 4 0 0 0 0 0 6 0 16200 900 1800 0 39600 10800 32400 32400 3 32400 36000 2 604800 86400 0 518400 201600 162000 324000 0 0 1800 2700 21600 32400 900 28800 172800 39600 0 0 0 0 0 0 0 1 0 0 0 0 0 0 900 19800 28800 39600 0 25200 86400 43200 0 86400 604800 259200 900" chainCosts="0.0">
<ns4:wrappedTourEvents>
<ns4:TourEvent tourIndex="0" period="0" startTime="28800" logisticPointId="123">
<ns4:wrappedDescriptions>
<ns0:String>SERVICE</ns0:String>
<ns0:String>IS_IN_SERVICE_INTERVAL</ns0:String>
</ns4:wrappedDescriptions>
<ns4:wrappedViolations/>
</ns4:TourEvent>
<ns4:TourEvent tourIndex="0" period="318" startTime="28800" logisticPointId="-1">
<ns0:String>DRIVING</ns0:String>
</ns4:TourEvent>
<ns4:TourEvent tourIndex="0" period="900" startTime="29118" logisticPointId="3464">
</ns4:TourEvent>
<ns4:TourEvent tourIndex="0" period="36" startTime="30018" logisticPointId="-1">
</ns4:TourEvent>
<ns4:TourEvent tourIndex="0" period="900" startTime="30054" logisticPointId="3465">
</ns4:TourEvent>
<ns4:TourEvent tourIndex="0" period="328" startTime="30954" logisticPointId="-1">
</ns4:TourEvent>
<ns4:TourEvent tourIndex="0" period="0" startTime="31282" logisticPointId="123">
</ns4:TourEvent>
</ns4:wrappedTourEvents>
</ns4:result>
<ns4:wrappedTours>
<ns4:Tour ignoreIntermediatePeriodOfPreviousTour="false" vehicleFixed="false" tourPointFixation="NONE" id="371" startTimeFixed="false">
<ns4:result remainingPeriods="22 serialization::archive 9 0 2 0 0 1 4 0 4 0 0 0 0 16200 0 0 0 1 0 39600 0 28800 0 0 3 2147483647 2147483647 2147483647 0 0 0 0 0 1 0 0 0 28800 0 0 28800 0 0 633600 0 0 6 0 0 0 28800 0 0 0 0 0 0 0 0 0 3 0 0 31282 2147483647 0 31282 0 0 0 4 0 0 0 0 0 0 0 2 0 0 2 0 0 0 0 0 4 0 0 0 0 4 0 0 0 0 0 6 0 16200 900 1800 0 39600 10800 32400 32400 3 32400 36000 2 604800 86400 0 518400 201600 162000 324000 0 0 1800 2700 21600 32400 900 28800 172800 39600 0 0 0 0 0 0 0 1 0 0 0 0 0 0 900 19800 28800 39600 0 25200 86400 43200 0 86400 604800 259200 900" tourChanged="true" depotAvailabilityForDeliveries="0" depotUnloadingPeriod="0" depotUploadingPeriod="0" coDriverRequired="false" startTimeLatest="28800" startTime="28800" transportPointCount="2" waitingPeriod="0" earliness="0" breakPeriod="0" restPeriod="0" servicePeriod="1800" maxDistanceBetweenTransportPoints="176" distanceFromFirstToLastTransportPoint="176" distance="4330" drivingPeriod="682" period="2482">
<ns4:deliveryQuantities>
<ns4:wrappedQuantities>
<ns0:Int>2160</ns0:Int>
</ns4:wrappedQuantities>
</ns4:deliveryQuantities>
<ns4:maxQuantities>
</ns4:maxQuantities>
<ns4:pickupQuantities>
<ns0:Int>0</ns0:Int>
</ns4:pickupQuantities>
<ns4:totalCosts totalCosts="0.0" costsPerHour="0.0" fixedCosts="0.0" costsPerKm="0.0"/>
<ns4:wrappedViolations xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true"/>
<ns4:wrappedVehicleRequirements>
<ns0:Int>4</ns0:Int>
<ns0:Int>478</ns0:Int>
</ns4:wrappedVehicleRequirements>
</ns4:result>
<ns4:wrappedTourPoints>
<ns4:TourPoint remainPlanned="false" tourFixed="false" type="DEPOT" id="123">
<ns4:result drivingDistance="0" startDistance="0" delay="0" earliness="0" restPeriodAtTourPoint="0" restPeriodOnRoad="0" breakPeriodAtTourPoint="0" breakPeriodOnRoad="0" servicePeriod="0" waitingPeriod="0" drivingPeriod="0" departureTime="28800" endServiceTime="28800" startServiceTime="28800" arrivalTime="28800">
<ns4:currentQuantities>
</ns4:currentQuantities>
<ns4:wrappedTourPointViolations xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true"/>
</ns4:result>
</ns4:TourPoint>
<ns4:TourPoint remainPlanned="true" tourFixed="true" type="TRANSPORT_POINT" id="3464">
<ns4:result drivingDistance="2037" startDistance="2037" delay="0" earliness="0" restPeriodAtTourPoint="0" restPeriodOnRoad="0" breakPeriodAtTourPoint="0" breakPeriodOnRoad="0" servicePeriod="900" waitingPeriod="0" drivingPeriod="318" departureTime="30018" endServiceTime="30018" startServiceTime="29118" arrivalTime="29118" orderId="3464">
<ns0:Int>1080</ns0:Int>
</ns4:result>
</ns4:TourPoint>
<ns4:TourPoint remainPlanned="true" tourFixed="true" type="TRANSPORT_POINT" id="3465">
<ns4:result drivingDistance="176" startDistance="2213" delay="0" earliness="0" restPeriodAtTourPoint="0" restPeriodOnRoad="0" breakPeriodAtTourPoint="0" breakPeriodOnRoad="0" servicePeriod="900" waitingPeriod="0" drivingPeriod="36" departureTime="30954" endServiceTime="30954" startServiceTime="30054" arrivalTime="30054" orderId="3465">
</ns4:result>
</ns4:TourPoint>
<ns4:result drivingDistance="2117" startDistance="4330" delay="0" earliness="0" restPeriodAtTourPoint="0" restPeriodOnRoad="0" breakPeriodAtTourPoint="0" breakPeriodOnRoad="0" servicePeriod="0" waitingPeriod="0" drivingPeriod="328" departureTime="31282" endServiceTime="31282" startServiceTime="31282" arrivalTime="31282">
</ns4:result>
</ns4:TourPoint>
</ns4:wrappedTourPoints>
</ns4:Tour>
</ns4:wrappedTours>
</ns4:Chain>
</ns4:wrappedChains>
<ns4:result totalChainCosts="0.0" totalTourCosts="0.0" totalTourDistance="4330" totalTourDrivingPeriod="682" totalTourPeriod="2482" totalTourCount="1">
<ns4:wrappedScheduledOrderIds>
<ns0:Int>3464</ns0:Int>
<ns0:Int>3465</ns0:Int>
</ns4:wrappedScheduledOrderIds>
<ns4:wrappedScheduledVehicleIds>
<ns0:Int>25</ns0:Int>
</ns4:wrappedScheduledVehicleIds>
<ns4:wrappedUnscheduledVehicleIds>
<ns0:Int>1</ns0:Int>
</ns4:wrappedUnscheduledVehicleIds>
</ns4:result>
</ns3:result>
</ns3:planBasicToursResponse>
</soap:Body>
</soap:Envelope>
François
