xTour and tour points fixation
Flegregeois
Post by Flegregeois »
Here is the description of my issue with xTour and tour point fixation :
I have two basic input tours with one tour point in each of them. See below their skeleton :
Input Plan
T1 : D – TP1 – D
T2 : D – TP2 – D
I set on the TP1 and TP2 the attributes tourFixed and remainPlanned to true
I’m expecting to get back in the output plan the same two tours because I fixed them.
But xTour returns one single tour with the merge of the two input tours.
Do I miss something ? ( the use case is voluntary reduced to two orders for the convenience of the explanation)
If I add the fixation of the vehicle (attribute vehicleFixed) on each of the input tour then I get the expected result.
I don't know why, I can't upload a file :-(
I put the request here:
  <SOAP-ENV:Header xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/"/>
  <soap:Body>
    <planBasicTours xmlns="http://types.xtour.xserver.ptvag.com" xmlns:ns2="http://xtour.xserver.ptvag.com" xmlns:ns3="http://wrappertypes.service.jabba.ptvag.com" xmlns:ns4="http://common.xserver.ptvag.com" xmlns:ns5="http://baseservices.service.jabba.ptvag.com" xmlns:ns6="http://xmap.xserver.ptvag.com" xmlns:ns7="http://exception.core.jabba.ptvag.com">
      <ArrayOfTransportOrder_1>
        <ns2:TransportOrder xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" id="3464" priority="1" trailerLoadingForbidden="false" xsi:type="ns2:TransportDepot">
          <ns2:maxLoadingArea xsi:nil="true"/>
          <ns2:minLoadingArea xsi:nil="true"/>
          <ns2:wrappedVehicleCategories xsi:nil="true"/>
          <ns2:wrappedVehicleExclusions xsi:nil="true"/>
          <ns2:wrappedVehicleRequirements>
            <ns3:Int>4</ns3:Int>
            <ns3:Int>478</ns3:Int>
          </ns2:wrappedVehicleRequirements>
          <ns2:deliveryQuantities>
            <ns2:wrappedQuantities>
              <ns3:Int>1080</ns3:Int>
            </ns2:wrappedQuantities>
          </ns2:deliveryQuantities>
          <ns2:wrappedDepotIds xsi:nil="true"/>
          <ns2:pickupQuantities xsi:nil="true"/>
          <ns2:transportPoint allowServiceSplit="false" coDriverRequired="false" id="3464" openingIntervalConstraint="COMPLETE_SERVICE" servicePeriod="900" tourSection="0" useServicePeriodForRecreation="false">
            <ns2:location>
              <ns4:kml xsi:nil="true"/>
              <ns4:point x="6.1642" y="49.21532"/>
            </ns2:location>
            <ns2:wrappedOpeningIntervals>
              <ns2:Interval from="28800" till="61200"/>
            </ns2:wrappedOpeningIntervals>
          </ns2:transportPoint>
        </ns2:TransportOrder>
        <ns2:TransportOrder xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" id="3465" priority="1" trailerLoadingForbidden="false" xsi:type="ns2:TransportDepot">
          <ns2:transportPoint allowServiceSplit="false" coDriverRequired="false" id="3465" openingIntervalConstraint="COMPLETE_SERVICE" servicePeriod="900" tourSection="0" useServicePeriodForRecreation="false">
            <ns2:location>
              <ns4:point x="6.16392" y="49.21661"/>
            </ns2:location>
      </ArrayOfTransportOrder_1>
      <ArrayOfDepot_2>
        <ns2:Depot id="123">
          <ns2:location>
            <ns4:kml xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true"/>
            <ns4:point x="6.1637" y="49.20272"/>
          </ns2:location>
          <ns2:wrappedOpeningIntervals xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true"/>
        </ns2:Depot>
      </ArrayOfDepot_2>
      <Fleet_3>
        <ns2:wrappedTrailers xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true"/>
        <ns2:wrappedTrains xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true"/>
        <ns2:wrappedVehicles>
          <ns2:Vehicle departureTimeFixed="28800" depotIdEnd="123" depotIdStart="123" dimaId="2" drivingPeriodFactor="1.0" id="1" ignoreIntermediatePeriodBeforeFirstTour="false" ignoreTransportPointServicePeriod="false" isPreloaded="false" servicePeriodFactor="1.0" toursMustFitIntoSingleOperatingInterval="false">
            <ns2:wrappedOperatingIntervals>
              <ns2:Interval from="28800" till="43200"/>
            </ns2:wrappedOperatingIntervals>
            <ns2:capacities>
              <ns2:wrappedCapacities>
                <ns2:Quantities>
                    <ns3:Int>14400</ns3:Int>
                </ns2:Quantities>
              </ns2:wrappedCapacities>
            </ns2:capacities>
            <ns2:costs xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true"/>
            <ns2:driverSettings breakRuleActive="false" dailyRestRuleActive="false" regulationsId="1" weeklyRestRuleActive="false" workingRuleActive="false">
              <ns2:maximumTourPeriodRestriction xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true"/>
            </ns2:driverSettings>
            <ns2:wrappedAreaNumbers xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true"/>
            <ns2:endLocation xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true"/>
            <ns2:maxLoadingArea xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true"/>
            <ns2:minLoadingArea xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true"/>
            <ns2:restrictions maxTourCountPerChain="1"/>
            <ns2:startLocation xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true"/>
            <ns2:wrappedTransportEquipments>
              <ns3:Int>21</ns3:Int>
              <ns3:Int>10</ns3:Int>
              <ns3:Int>9</ns3:Int>
              <ns3:Int>20</ns3:Int>
              <ns3:Int>3</ns3:Int>
              <ns3:Int>8</ns3:Int>
              <ns3:Int>25</ns3:Int>
              <ns3:Int>16</ns3:Int>
              <ns3:Int>24</ns3:Int>
              <ns3:Int>14</ns3:Int>
              <ns3:Int>12</ns3:Int>
              <ns3:Int>22</ns3:Int>
              <ns3:Int>5</ns3:Int>
              <ns3:Int>18</ns3:Int>
              <ns3:Int>11</ns3:Int>
              <ns3:Int>7</ns3:Int>
              <ns3:Int>15</ns3:Int>
              <ns3:Int>17</ns3:Int>
              <ns3:Int>2</ns3:Int>
              <ns3:Int>6</ns3:Int>
              <ns3:Int>19</ns3:Int>
              <ns3:Int>23</ns3:Int>
              <ns3:Int>13</ns3:Int>
              <ns3:Int>1</ns3:Int>
              <ns3:Int>384</ns3:Int>
              <ns3:Int>378</ns3:Int>
              <ns3:Int>377</ns3:Int>
              <ns3:Int>379</ns3:Int>
              <ns3:Int>372</ns3:Int>
              <ns3:Int>382</ns3:Int>
              <ns3:Int>368</ns3:Int>
              <ns3:Int>369</ns3:Int>
              <ns3:Int>383</ns3:Int>
              <ns3:Int>380</ns3:Int>
              <ns3:Int>370</ns3:Int>
            </ns2:wrappedTransportEquipments>
          </ns2:Vehicle>
          <ns2:Vehicle departureTimeFixed="28800" depotIdEnd="123" depotIdStart="123" dimaId="2" drivingPeriodFactor="1.0" id="25" ignoreIntermediatePeriodBeforeFirstTour="false" ignoreTransportPointServicePeriod="false" isPreloaded="false" servicePeriodFactor="1.0" toursMustFitIntoSingleOperatingInterval="false">
            <ns2:capacities>
                <ns2:Quantities>
                </ns2:Quantities>
            </ns2:capacities>
              <ns3:Int>472</ns3:Int>
              <ns3:Int>486</ns3:Int>
              <ns3:Int>470</ns3:Int>
              <ns3:Int>493</ns3:Int>
              <ns3:Int>409</ns3:Int>
              <ns3:Int>408</ns3:Int>
              <ns3:Int>481</ns3:Int>
              <ns3:Int>476</ns3:Int>
              <ns3:Int>504</ns3:Int>
              <ns3:Int>463</ns3:Int>
              <ns3:Int>491</ns3:Int>
              <ns3:Int>458</ns3:Int>
              <ns3:Int>506</ns3:Int>
              <ns3:Int>414</ns3:Int>
              <ns3:Int>422</ns3:Int>
              <ns3:Int>498</ns3:Int>
              <ns3:Int>492</ns3:Int>
          </ns2:Vehicle>
        </ns2:wrappedVehicles>
      </Fleet_3>
      <PlanningParams_4 xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" availableMachineTime="120" coDriverTransportPointsInSeparateTours="false" constructionStep="true" endSequencingStep="true" improvementStep="true" middleSequencingStep="true" sequencingMethod="cSMThoroughOpt" startSequencingStep="true" tourReductionStep="false" xsi:type="ns2:StandardParams">
        <ns2:wrappedDistanceMatrixCalculation>
          <ns2:DistanceMatrixCalculation deleteAfterUsage="true" deleteBeforeUsage="true" dimaId="2" xsi:type="ns2:DistanceMatrixByRoad"/>
        </ns2:wrappedDistanceMatrixCalculation>
        <ns2:wrappedLoadingFunctions xsi:nil="true"/>
        <ns2:wrappedProductIncompatibilities xsi:nil="true"/>
        <ns2:wrappedRegulations>
          <ns2:RegulationsBase beginningOfCalendarWeek="0" id="1" xsi:type="ns2:DriverRegulations">
            <ns2:breakIntervals breakPeriod="0">
              <ns2:wrappedIntervals>
                <ns2:Interval from="0" till="0"/>
              </ns2:wrappedIntervals>
            </ns2:breakIntervals>
            <ns2:breakRule xsi:nil="true"/>
            <ns2:dailyRestRule xsi:nil="true"/>
            <ns2:weeklyRestRule xsi:nil="true"/>
            <ns2:workingRule xsi:nil="true"/>
          </ns2:RegulationsBase>
        </ns2:wrappedRegulations>
        <ns2:restrictions>
          <ns2:tourRestrictions maxDistance="500000" maxDistanceBetweenTransportPoints="7000"/>
        </ns2:restrictions>
        <ns2:goalImportance chainPeriodRank="0" tourCountRank="0" tourDistanceRank="3" tourDrivingPeriodRank="0" tourPeriodRank="0" unplannedOrdersRank="0" vehicleCountRank="1"/>
      </PlanningParams_4>
      <Plan_5>
        <ns2:wrappedChains>
          <ns2:Chain vehicleId="1">
            <ns2:result xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true"/>
            <ns2:wrappedTours>
              <ns2:Tour id="370" ignoreIntermediatePeriodOfPreviousTour="false" startTimeFixed="false" vehicleFixed="false">
                <ns2:restrictions xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true"/>
                <ns2:wrappedTourPoints>
                  <ns2:TourPoint id="123" remainPlanned="false" tourFixed="false" type="DEPOT">
                  </ns2:TourPoint>
                  <ns2:TourPoint id="3464" remainPlanned="true" tourFixed="true" type="TRANSPORT_POINT">
                  </ns2:TourPoint>
                  </ns2:TourPoint>
                </ns2:wrappedTourPoints>
              </ns2:Tour>
            </ns2:wrappedTours>
          </ns2:Chain>
          <ns2:Chain vehicleId="25">
            <ns2:wrappedTours>
              <ns2:Tour id="371" ignoreIntermediatePeriodOfPreviousTour="false" startTimeFixed="false" vehicleFixed="false">
                  </ns2:TourPoint>
                  <ns2:TourPoint id="3465" remainPlanned="true" tourFixed="true" type="TRANSPORT_POINT">
                  </ns2:TourPoint>
                  </ns2:TourPoint>
              </ns2:Tour>
            </ns2:wrappedTours>
          </ns2:Chain>
        </ns2:wrappedChains>
      </Plan_5>
      <CallerContext_6>
        <ns5:wrappedProperties>
          <ns5:CallerContextProperty key="CoordFormat" value="OG_GEODECIMAL"/>
          <ns5:CallerContextProperty key="TenantId" value="68d9ee7e-b551-11e6-b3a3-ecf4bb142308"/>
          <ns5:CallerContextProperty key="Profile" value="V-ESSENCE-WO-TOLLROADS"/>
        </ns5:wrappedProperties>
      </CallerContext_6>
    </planBasicTours>
  </soap:Body>
</soap:Envelope>
and the response:
<?xml version="1.0" encoding="UTF-8"?><soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/">
  <soap:Body>
    <ns3:planBasicToursResponse xmlns:ns6="http://exception.core.jabba.ptvag.com" xmlns:ns2="http://baseservices.service.jabba.ptvag.com" xmlns:ns1="http://common.xserver.ptvag.com" xmlns:ns3="http://types.xtour.xserver.ptvag.com" xmlns:ns0="http://wrappertypes.service.jabba.ptvag.com" xmlns:ns4="http://xtour.xserver.ptvag.com">
      <ns3:result>
        <ns4:wrappedChains>
          <ns4:Chain vehicleId="25">
            <ns4:result distanceToEndLocation="0" periodToEndLocation="0" distanceFromStartLocation="0" periodFromStartLocation="0" endTime="31282" drivingPeriod="682" remainingPeriods="22 serialization::archive 9 0 2 0 0 1 4 0 4 0 0 0 0 16200 0 0 0 1 0 39600 0 28800 0 0 3 2147483647 2147483647 2147483647 0 0 0 0 0 1 0 0 0 28800 0 0 28800 0 0 633600 0 0 6 0 0 0 28800 0 0 0 0 0 0 0 0 0 3 0 0 31282 2147483647 0 31282 0 0 0 4 0 0 0 0 0 0 0 2 0 0 2 0 0 0 0 0 4 0 0 0 0 4 0 0 0 0 0 6 0 16200 900 1800 0 39600 10800 32400 32400 3 32400 36000 2 604800 86400 0 518400 201600 162000 324000 0 0 1800 2700 21600 32400 900 28800 172800 39600 0 0 0 0 0 0 0 1 0 0 0 0 0 0 900 19800 28800 39600 0 25200 86400 43200 0 86400 604800 259200 900" chainCosts="0.0">
              <ns4:wrappedTourEvents>
                <ns4:TourEvent tourIndex="0" period="0" startTime="28800" logisticPointId="123">
                  <ns4:wrappedDescriptions>
                    <ns0:String>SERVICE</ns0:String>
                    <ns0:String>IS_IN_SERVICE_INTERVAL</ns0:String>
                  </ns4:wrappedDescriptions>
                  <ns4:wrappedViolations/>
                </ns4:TourEvent>
                <ns4:TourEvent tourIndex="0" period="318" startTime="28800" logisticPointId="-1">
                    <ns0:String>DRIVING</ns0:String>
                </ns4:TourEvent>
                <ns4:TourEvent tourIndex="0" period="900" startTime="29118" logisticPointId="3464">
                </ns4:TourEvent>
                <ns4:TourEvent tourIndex="0" period="36" startTime="30018" logisticPointId="-1">
                </ns4:TourEvent>
                <ns4:TourEvent tourIndex="0" period="900" startTime="30054" logisticPointId="3465">
                </ns4:TourEvent>
                <ns4:TourEvent tourIndex="0" period="328" startTime="30954" logisticPointId="-1">
                </ns4:TourEvent>
                <ns4:TourEvent tourIndex="0" period="0" startTime="31282" logisticPointId="123">
                </ns4:TourEvent>
              </ns4:wrappedTourEvents>
            </ns4:result>
            <ns4:wrappedTours>
              <ns4:Tour ignoreIntermediatePeriodOfPreviousTour="false" vehicleFixed="false" tourPointFixation="NONE" id="371" startTimeFixed="false">
                <ns4:result remainingPeriods="22 serialization::archive 9 0 2 0 0 1 4 0 4 0 0 0 0 16200 0 0 0 1 0 39600 0 28800 0 0 3 2147483647 2147483647 2147483647 0 0 0 0 0 1 0 0 0 28800 0 0 28800 0 0 633600 0 0 6 0 0 0 28800 0 0 0 0 0 0 0 0 0 3 0 0 31282 2147483647 0 31282 0 0 0 4 0 0 0 0 0 0 0 2 0 0 2 0 0 0 0 0 4 0 0 0 0 4 0 0 0 0 0 6 0 16200 900 1800 0 39600 10800 32400 32400 3 32400 36000 2 604800 86400 0 518400 201600 162000 324000 0 0 1800 2700 21600 32400 900 28800 172800 39600 0 0 0 0 0 0 0 1 0 0 0 0 0 0 900 19800 28800 39600 0 25200 86400 43200 0 86400 604800 259200 900" tourChanged="true" depotAvailabilityForDeliveries="0" depotUnloadingPeriod="0" depotUploadingPeriod="0" coDriverRequired="false" startTimeLatest="28800" startTime="28800" transportPointCount="2" waitingPeriod="0" earliness="0" breakPeriod="0" restPeriod="0" servicePeriod="1800" maxDistanceBetweenTransportPoints="176" distanceFromFirstToLastTransportPoint="176" distance="4330" drivingPeriod="682" period="2482">
                  <ns4:deliveryQuantities>
                    <ns4:wrappedQuantities>
                      <ns0:Int>2160</ns0:Int>
                    </ns4:wrappedQuantities>
                  </ns4:deliveryQuantities>
                  <ns4:maxQuantities>
                  </ns4:maxQuantities>
                  <ns4:pickupQuantities>
                      <ns0:Int>0</ns0:Int>
                  </ns4:pickupQuantities>
                  <ns4:totalCosts totalCosts="0.0" costsPerHour="0.0" fixedCosts="0.0" costsPerKm="0.0"/>
                  <ns4:wrappedViolations xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true"/>
                  <ns4:wrappedVehicleRequirements>
                    <ns0:Int>4</ns0:Int>
                    <ns0:Int>478</ns0:Int>
                  </ns4:wrappedVehicleRequirements>
                </ns4:result>
                <ns4:wrappedTourPoints>
                  <ns4:TourPoint remainPlanned="false" tourFixed="false" type="DEPOT" id="123">
                    <ns4:result drivingDistance="0" startDistance="0" delay="0" earliness="0" restPeriodAtTourPoint="0" restPeriodOnRoad="0" breakPeriodAtTourPoint="0" breakPeriodOnRoad="0" servicePeriod="0" waitingPeriod="0" drivingPeriod="0" departureTime="28800" endServiceTime="28800" startServiceTime="28800" arrivalTime="28800">
                      <ns4:currentQuantities>
                      </ns4:currentQuantities>
                      <ns4:wrappedTourPointViolations xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true"/>
                    </ns4:result>
                  </ns4:TourPoint>
                  <ns4:TourPoint remainPlanned="true" tourFixed="true" type="TRANSPORT_POINT" id="3464">
                    <ns4:result drivingDistance="2037" startDistance="2037" delay="0" earliness="0" restPeriodAtTourPoint="0" restPeriodOnRoad="0" breakPeriodAtTourPoint="0" breakPeriodOnRoad="0" servicePeriod="900" waitingPeriod="0" drivingPeriod="318" departureTime="30018" endServiceTime="30018" startServiceTime="29118" arrivalTime="29118" orderId="3464">
                          <ns0:Int>1080</ns0:Int>
                    </ns4:result>
                  </ns4:TourPoint>
                  <ns4:TourPoint remainPlanned="true" tourFixed="true" type="TRANSPORT_POINT" id="3465">
                    <ns4:result drivingDistance="176" startDistance="2213" delay="0" earliness="0" restPeriodAtTourPoint="0" restPeriodOnRoad="0" breakPeriodAtTourPoint="0" breakPeriodOnRoad="0" servicePeriod="900" waitingPeriod="0" drivingPeriod="36" departureTime="30954" endServiceTime="30954" startServiceTime="30054" arrivalTime="30054" orderId="3465">
                    </ns4:result>
                  </ns4:TourPoint>
                    <ns4:result drivingDistance="2117" startDistance="4330" delay="0" earliness="0" restPeriodAtTourPoint="0" restPeriodOnRoad="0" breakPeriodAtTourPoint="0" breakPeriodOnRoad="0" servicePeriod="0" waitingPeriod="0" drivingPeriod="328" departureTime="31282" endServiceTime="31282" startServiceTime="31282" arrivalTime="31282">
                    </ns4:result>
                  </ns4:TourPoint>
                </ns4:wrappedTourPoints>
              </ns4:Tour>
            </ns4:wrappedTours>
          </ns4:Chain>
        </ns4:wrappedChains>
        <ns4:result totalChainCosts="0.0" totalTourCosts="0.0" totalTourDistance="4330" totalTourDrivingPeriod="682" totalTourPeriod="2482" totalTourCount="1">
          <ns4:wrappedScheduledOrderIds>
            <ns0:Int>3464</ns0:Int>
            <ns0:Int>3465</ns0:Int>
          </ns4:wrappedScheduledOrderIds>
          <ns4:wrappedScheduledVehicleIds>
            <ns0:Int>25</ns0:Int>
          </ns4:wrappedScheduledVehicleIds>
          <ns4:wrappedUnscheduledVehicleIds>
            <ns0:Int>1</ns0:Int>
          </ns4:wrappedUnscheduledVehicleIds>
        </ns4:result>
      </ns3:result>
    </ns3:planBasicToursResponse>
  </soap:Body>
</soap:Envelope>
best regards,
François
Re: xTour and tour points fixation
Hello Francois,
please provide the comlpete requests and responses so we can analyse them.
Flegregeois
just update my topic with the request.
François
Has been jira'd...
