Problem with Housenumber-Range in Street field
Posted: Wed Oct 12, 2016 12:13 pm
we just encountered an issue with an address and I was trying out different settings in the xLocateServer but I wasn't able to get better results.
This will return hits with completely different postcodes, but with Streets like "Straße 106" and "Straße 103".
If I remove the "/" from the street and replace it with a space, it works fine. "-" also does not work.
It's unfortunate that I cannot use put the house number in the appropriate field, since that would fix everything.
Any suggestings?
Sven Howard
country="D"
postCode="12105 "
city="Berlin"
street="Ringstr. 103/106"If I remove the "/" from the street and replace it with a space, it works fine. "-" also does not work.
Any suggestings?
Sven Howard
