Gas stations or Parking lots for trucks
Posted: Thu Jul 14, 2016 1:25 pm
by VPlachy
how or in what layer can be viewed gas stations or parking lots for trucks on the map?
Thank you
Re: Gas stations or Parking lots for trucks
Posted: Thu Jul 14, 2016 3:35 pm
Hello Vlad,
PTV can offer so-called POINTS OF INTEREST which contain various categories such as
- Sample image that displays POI based on SMO Layer.
The categories 7369, 7313, 7311 are visible.
- 7369 - Open Parking Area
- 7313 - Parking Garage
- 7311 - Petrol Station
Those POIs come from HERE or TOMTOM and the categories are listed
http://xserver.ptvgroup.com/fileadmin/f ... _Types.htm
Further information is available at
http://xserver.ptvgroup.com/fileadmin/f ... n%7C_____7
And here is a sample XML request for this:
<?xml version="1.0"?>
<Envelope xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns="http://schemas.xmlsoap.org/soap/envelope/">
<Body>
<renderMap xmlns="http://types.xmap.xserver.ptvag.com">
<MapSection_1 scale="500" scrollHorizontal="0" scrollVertical="0" zoom="0">
<center xmlns="http://xmap.xserver.ptvag.com">
<kml xsi:nil="true" xmlns="http://common.xserver.ptvag.com" />
<point x="682055.81" y="6372194.6" xmlns="http://common.xserver.ptvag.com" />
</center>
</MapSection_1>
<MapParams_2 showScale="true" useMiles="false" />
<ImageInfo_3 format="GIF" height="777" imageParameter="" width="777" />
<ArrayOfLayer_4>
<Layer xsi:type="SMOLayer" name="default.points-of-interest.default;featurecode in ('7311','7369','7313')" visible="true" configuration="" objectInfos="REFERENCEPOINT" xmlns="http://xmap.xserver.ptvag.com" />
</ArrayOfLayer_4>
<boolean_5>true</boolean_5>
<CallerContext_6>
<CallerContextProperty key="CoordFormat" value="PTV_MERCATOR" />
<CallerContextProperty />
</wrappedProperties>
</CallerContext_6>
</renderMap>
</Body>
</Envelope>
Do you need more info?
Posted: Fri Jul 15, 2016 8:13 am
by VPlachy
Hello Brend,
thank you for your information.
I have one question yet. How can I add this layer to a map in C # project? Somehow, I fail to program it.
Best regards Vladimir
Posted: Fri Jul 15, 2016 8:58 am
Hello Vlad,
if you want to use a native layer for painting just use the following one:
new SMOLayer()
name = "default.points-of-interest.default;featurecode in ('7311','7369','7313')",
objectInfos = ObjectInfoType.REFERENCEPOINT,
visible = true
But: if you work with the xServer.NET control I have to involve a colleague to request a sample. I hope Oliver can provide some nice code.
PS: I moved the topic to xMap forum as it is not a routing topic
Posted: Fri Jul 15, 2016 9:22 am
and here is some info from Oliver:
Posted: Thu Mar 24, 2022 1:53 pm
Recently I've been asked whether we can offer a search for EV charging stations (electronic vehicles).
As some of you might have noticed: there's no POI search in xServer 2 but we implemented this approach in the PTV Developer API which was released for PROD in summer 2021.
- Result of a search for EV charging stations around the location of PTV's head quarter. I used the new PTV Developer API
For details check the
documentation of the Places API.
