Hello Martin,
if this error appears this means that the api key you used for the transaction respectively the so-called plan to which the token belongs to does not include access to the method you called, e.g. to the Route Optimization Optiflow API / startOptimization.
Please get in touch with your PTV account manager to check the conditions to get the correct plan. It will be helpful for us if you provide your
subscription ID so we can identify the account. As described in the article we manage various limitations via the plans.
The complete message also includes a traceId and an errorId : could be helpful sometimes if you mention them and also the endpoint that caused an issue.
"traceId": "xxx",
"errorId": "yyy",
"description": "Insufficient access rights.",
"errorCode": "GENERAL_FORBIDDEN",
"details": {
"message": "You do not have permission to access this app."
PS: in this particular case the underlying plan was a "migration plan" that is dedicated to serve xServer users to use the optimization APIs based on xTour 2 technology (both already in maintenance mode):
Remember: the best optimization in town is the
