REQ: ETA calculation process for guided navigation
Posted: Wed Jun 18, 2025 7:37 am
a partner wants to build an ETA calculation based on a guided navigation process in the backend (not on the mobile device).
We discussed an idea, but before we implement this with efforts I'd like to get a quick feedback about the approach or maybe a correction / alternative approach. Here's how we would tackle this based on xServer2 (PTV Developer offers a dedicated method getEstimatedTimeOfArrival / concept)
  • Avaliable Input
    • Vehicle's current (lat/lon) plus Timestamp (let's call it CUR)
    • Precalculated BCR file including multiple "silent via points" (SVP)
  • Output
    • Reconstructed route with proper ETAs for each waypoint - geometry should follow the precalculated BCR polylines / SVP
and here's the meta description of the process:
  • use a 1:N matrix call to identify the SVP which can be reached fastest : let's call it SVP*. Gather the required traveltime from CUR to SVP* and determine the arrival time at SVP*
  • identify the subsequence of SVPs that begins with SVP* (in other words: cut all SVPs prior to SVP*)
  • perform a track matching with this subsequence from SVP* to SVP.Last
What we do NOT know:
  • Which profile was used for the BCR calculation. Therefore we have to let the user pick a profile.
The doubts I have:
  • Selection of SVP* : could the dima lead to the wrong SVP backwards?
  • Are SVPs positions valid input for the track matching?
Re: REQ: ETA calculation process for guided navigation
Posted: Wed Jun 18, 2025 8:00 am
by Joost
For a usable output it depends how dense the SVP's are. If they are to spread out from each other you will get a lot of broken paths. In that case you are better off with a regular routing and use manipulate waypoints for the SVP's.
