New in Developer 16.5.-3.6.2025
Here's an update on the latest developments in PTV Developer... you can also find that info in each API's change list:
Data UpdatesANNOUNCEMENT02.06.2025Updated toll prices in Slovenia, valid from 2025-01-01.
Data UpdatesANNOUNCEMENT21.05.2025Updated toll prices in Netherlands, valid from 2025-01-01.
Geocoding & Places API1.17.1IMPROVEMENT22.05.2025The endpoint locations/by-address now returns a RESULT_BASED total score of 100, in cases where the INPUT_AND_RESULT_BASED total score would return 100.
Geocoding Batch API1.2.0IMPROVEMENT22.05.2025The quality of errors is further improved.
Map Matching API1.9.0IMPROVEMENT22.05.2025The quality of errors and warnings is again improved by identifying more specific causes.
Matrix Routing API1.9.6IMPROVEMENT27.05.2025The locations should be located within a rectangle of 1000 kilometers maximum for a time-dependent matrix.
Matrix Routing API1.9.5IMPROVEMENT21.05.2025The handling of unavoidable live traffic situations is improved.
Route Optimization OptiFlow API1.15.0FEATURE03.06.2025Added the option to give a name and tags to optimizations. Name, tags and creation timestamp are returned when retrieving an optimization result.
Route Optimization OptiFlow API1.14.0FEATURE28.05.2025Added overdistance cost to define an extra cost per kilometer if the route's distance exceeds a threshold.
Route Optimization OptiFlow API1.14.0FEATURE28.05.2025Added overstop cost to define an extra cost per stop if the route's number of stops exceeds a threshold.
Route Optimization OptiFlow API1.14.0FEATURE28.05.2025Added repositioning effort to restrict the repositioning of goods in the vehicle.
Route Optimization OptiFlow API1.13.1IMPROVEMENT23.05.2025The response parameter 'parameter' of type 'CausingError' starts with '$.' when denoting a JSONPath.
Route Optimization OptiFlow API1.13.1BUGFIX23.05.2025Requests are now correctly validated for duplicated and unrecognized parameters.
Routing API1.36.0FEATURE15.05.2025Added query parameter 'maximumPollingPeriod' to the methods 'getReachableAreas' and 'getReachableLocations' to enable waiting for the calculation completion up to a specified maximum polling period.
Routing API1.36.0IMPROVEMENT15.05.2025The handling of unavoidable live traffic situations is improved.
Routing API1.36.0IMPROVEMENT15.05.2025The quality and performance of intercontinental routes between Europe and Africa is improved.
Routing API1.36.0IMPROVEMENT15.05.2025The quality of warnings is improved by identifying more specific causes.
