v2.37: "The operation 'createFeatureLayer' can now support segments of type COMBINED_TRANSPORT."
Posted: Fri May 30, 2025 10:54 am
We improved the xServer v2.37 but unfortunately the following "impro release note" managed to escape from the official docs:
Here's what that means:
Quite often users want to determine which explicit ferries they want to block in their "world" (or to be more precise: they want to restrict the ferries they want to see in routing results).
Let's look into this request:
The purpose:
But trust me - the feature has been implemented!The operation 'createFeatureLayer' can now support segments of type COMBINED_TRANSPORT."
The purpose:
- Create a custom feature layer scenario called "f1"
- ...based on the single segment "segmentIds": ["SEGM0002a453b15d...."], which is a COMBINED_TRANSPORT segment
- ...by blocking it
- ... in both directions
- ... anytime (no time domain given)
{ "features": [
{ "segmentIds": ["SEGM0002a453b15d...."],
"descriptions":
[ { "attributes": [{"key": "opening","value": "0"}], "timeDomain": null } ],
"direction": "BOTH"
"resultFields": { "binaryFeatureLayer": false },
"themeId": "PTV_RoadAttributes",
"featureScenario": "f1",
"requestProfile": {
"featureLayerProfile": {
"themes":
[ { "featureScenarios": ["f1"], "id": "PTV_RoadAttributes", "enabled": true
- In xServer 2.36 and before a custom feature layer did not support to handle ferry segments:
{ "faultInfo": { "$type": "InvalidValueFault", "hint": "Please make sure that this string is a response from a PTV xServer of the same version using the same map. Do not modify this string.", "parameter": "/createFeatureLayerRequest/features[]/@segmentIds[]", "value": "SEGM0002a453..." }, "message": "The encoded content is invalid." } - With xServer 2.37 this request now returns a successful response:
{ "$type": "FeatureLayerResponse", "featureLayerDescription": { "themeId": "PTV_RoadAttributes", "featureScenario": "f1", "tenant": "globaltenant", "scope": "globalscope", "createdAt": "2025-05-30T12:46:54.000+02:00", "lastUsedAt": "2025-05-30T12:46:54.000+02:00", "size": 29366, "providerInformation": "HERE 241h0", "mapVersion": "6188119842897510564" } }
- Creation of the layer was successful:
- Routing based on the scenario performs detour
- Visualization?
- How to maintain specific sets of ferries? (A single map contains thousands of COMBINED_TRANSPORT segments - often the clients want to block all but a few...
- When will this be availavble on PTV Developer?
- Provide your questions?
