v2.37: "The operation 'createFeatureLayer' can now support segments of type COMBINED_TRANSPORT."
Data which is used in a more general manner can be requested by xData service. Therefore this data is not provided by one of the other functional services, but concentrated in an own independent service.
Attention: this is not the platform for the data itself. If you have questions about missing data or the handling of binary maps please look at Data and Content.
We improved the xServer v2.37 but unfortunately the following "impro release note" managed to escape from the official docs:
But trust me - the feature has been implemented!
Here's what that means:
Quite often users want to determine which explicit ferries they want to block in their "world" (or to be more precise: they want to restrict the ferries they want to see in routing results).
Let's look into this request:
The purpose:
  • Create a custom feature layer scenario called "f1"
  • ...based on the single segment "segmentIds": ["SEGM0002a453b15d...."], which is a COMBINED_TRANSPORT segment
  • ...by blocking it
  • ... in both directions
  • ... anytime (no time domain given)
{ "features": [
        {   "segmentIds": ["SEGM0002a453b15d...."],
            "descriptions":
            [   {   "attributes": [{"key": "opening","value": "0"}], "timeDomain": null  }   ],
            "direction": "BOTH"
    "resultFields": { "binaryFeatureLayer": false  },
    "themeId": "PTV_RoadAttributes",
        "featureScenario": "f1",
            "requestProfile": {
        "featureLayerProfile": {
                "themes":
                [   {   "featureScenarios": ["f1"], "id": "PTV_RoadAttributes", "enabled": true
  • In xServer 2.36 and before a custom feature layer did not support to handle ferry segments:
      "faultInfo": {
        "$type": "InvalidValueFault",
        "hint": "Please make sure that this string is a response from a PTV xServer of the same version using the same map. Do not modify this string.",
        "parameter": "/createFeatureLayerRequest/features[]/@segmentIds[]",
        "value": "SEGM0002a453..."
      "message": "The encoded content is invalid."
  • With xServer 2.37 this request now returns a successful response:
      "$type": "FeatureLayerResponse",
      "featureLayerDescription": {
        "tenant": "globaltenant",
        "scope": "globalscope",
        "createdAt": "2025-05-30T12:46:54.000+02:00",
        "lastUsedAt": "2025-05-30T12:46:54.000+02:00",
        "size": 29366,
        "providerInformation": "HERE 241h0",
        "mapVersion": "6188119842897510564"
For those who are familiar with the xRouteToll2 Testclient:
  • Creation of the layer was successful:
  • Routing based on the scenario performs detour
Open questions:
  • Visualization?
  • How to maintain specific sets of ferries? (A single map contains thousands of COMBINED_TRANSPORT segments - often the clients want to block all but a few...
  • When will this be availavble on PTV Developer?
  • Provide your questions?
Re: v2.37: "The operation 'createFeatureLayer' can now support segments of type COMBINED_TRANSPORT."
this is now also reflected in the PTV Developer Data API:
Check the changes
valdasb
Post by valdasb »
Blocking some segments of type COMBINED_TRANSPORT is a very useful feature but is the opposite possible? I mean, is it possible to create new custom segments of type COMBINED_TRANSPORT?
Hello Valdas,
Is it possible to create new custom segments of type COMBINED_TRANSPORT?
The answer is simple: not possible.
All the editor functions we ever offered - whether this was based on
  • xServer1 + Map&Guide RoadEditor
  • xServer2 / xData2
  • PTV Developer Custom Attributes
were designed to override attributes of existing segments.
But we never offered to
  • create new road segments
  • create new teleporters / combined transport "segments"
This story is too huge and requires a full blown GIS system.
In other words:
  • PTV buys standard road networks incl. dozends of attributes from vendors such as HERE
  • PTV offers to override these attributes if they simply do not reflect "your own business reality" (due to error, not up2date, special agreements, ...)
valdasb
Post by valdasb »
OK, that's clear. But maybe You have any ideas of how to workaround the problem of missing train or ferry lines? Or "fix" the wrong ones? For example, we need to route the truck by Wörgl-Brenner train. xData gives the required train line:
"combinedTransport": {
"name": "Rola Wörgl-Brenner",
"type": "RAIL",
"duration": 18082,
"start": {"name": "Wörgl","country": "AT","coordinate": {
"x": 12.033915862,"y": 47.482539082
"destination": {
"name": "Trento","country": "IT","coordinate": {
"x": 11.096358212,"y": 46.103613833
But the train line returned is to Trento, which is 130km away from Brenner. So, I need either the way to add missing train to Brenner (which is not possible) or fix existing combined transport record by overriding it's destination. Any ideas?
I guess you are right : the relation Wörgl / Brenner is just the partial combined transport.
https://rola.railcargo.com/de/
Current situation  (2025.2H)
I therefore recommend that you create a ticket through the helpdesk:
  • The data contains only 2 out of 4 relations
  • The labels are incorrect
Real nameName in 2025.2H
Wörgl-Brennermissing
Brenner-Wörglmissing
Wörgl-TrentoRola Wörgl - Brenner (wrong)
Trento-WörglTrento - Rola Wörgl
In the meantime I can brief the data team and prepare the required supplier bug ticket towards HERE.
Ah - I've just been told that there's already a ticket for this... we'll push this internally...
