Release of PTV xServer 2.37.0
Posted: Wed May 28, 2025 3:00 pm
And as anounced this morning there's also a new xServer2:
The PTV xServer and the PTV Content Update Service 2.37 is released!
  • general
    • Improvement: Updated the Apache Tomcat.
  • xdata
    • Improvement: The operation 'createFeatureLayer' can now support segments of type COMBINED_TRANSPORT."
    • Bugfix: The response field 'networkClass' in the operations 'getSegments' and 'getCombinedTransportsByText' was off by 1 for segments of type 'COMBINED_TRANSPORT'.
  • xdima
    • Improvement: The handling of unavoidable traffic incidents is improved.
    • Bugfix: New toll data is properly selected after a map update.
  • xload
    • Improvement: Renamed the field 'stackOnTopOfNeighboringStacks' in the type 'StackingOptions' to 'stackOnTopOfMutipleStacks'. Please note that this is no longer experimental.
  • xroute
    • Feature: Added support for tour events of type 'DRIVING' to ensure the same behavior as for xTour results.
    • Feature: Added support for relaxing Feature Layer attributes with custom Feature Layer like raising the height of a bridge and no longer the most restrictive attribute is valid.
    • Improvement: The performance using high-performance routing is improved in particular when the field 'highPerformanceRoutingNetworkId' is not used.
    • Improvement: If a tour violation occurs during an event, this event is split into a non-violated and violated part to ensure the same behavior as for xTour results.
    • Improvement: The field 'exceedance' of type 'TimeViolation' contains the accurate time value including milliseconds.
    • Bugfix: The response field 'networkClass' in the operation 'calculateRoute' was off by 1 for segments of type 'COMBINED_TRANSPORT'.
    • Bugfix: Fixed bug where the field 'drivingTimeFactor' was not considered when using a path waypoint.
    • Bugfix: The field 'exceedance' of type 'TimeViolation' reported with a tour violation contains the exceedance at the end instead of the beginning of the event.
The on-premise solution can be found here: Customer Area (login required)
The cloud solution PTV xServer internet will be updated according to this plan:
  • 03.06.25: Productive system hosted in Europe
  • 04.06.25: Productive system hosted in US
  • 12.06.25: Productive system hosted in Australia
Thanks to the teams for the quick reaction!
