Categories of "relation status" in xDima2
Hi folks,
for demonstration purposes I calculated a dima with some special coinstraints:
  • 5 locations somewhere on the German island Sylt
  • A custom bounding rectangle which "excludes" the point in the far east
  • Violations allowed
I wanted to demonstrate that the dima is complete (5x5 relations) and splits the relations into 3 categories:
  • relation routed successful, without violations
  • relation routed successful, with violations
  • relation not routed successful, therefore estimated by direct distance
What surprises me: the point in the far east contributes with:
  • 3 times without violations
  • 2 times violated
  • 3 times estimated by direct distance
How can this be? I expected the location to be "unreachable" from a symmetric perspective.
Re: Categories of "relation status" in xDima2
OK, that was a tricky one - probably doesn't occur in reality ;-)
  • The isolated coordinate in the east (green pin) is linked to the closest segment (green star) that touches the rectangle's border.
  • That particular road is a oneway street which
    • enables the router to leave the place
    • but prevents him from reaching the eastern point
Thanks for the analysis, Frank!
That being said I recommend that you also check this article "xServer2: Handling of optimization on islands such as Sylt, Helgoland, ..." carefully if you are interested in "spatial" challenges ;-)
In this context of "relation calculated or not" I just got some info from our DEVs:
If a location cannot be linked (because it is located in an isolated area): how is the distance / traveltime from the original isolated waypoint to the last possible road segment point determined?
  • For off-road locations the speedForLinkDistance parameter is used to calculate the travel time based on the air-line distance to the linked road segment.
  • For relations that cannot be calculated:
    • Distance is air-line distance multiplied with detourFactor(default 1.38)
    • Travel time is calculated based on that distance and averageSpeed (default 60)
    • The flag estimatedByDirectDistance is set to true
    • There are different reasons why a relation cannot be calculated:
      • Violations are disabled and there is no valid route without violation.
      • Certain restrictions cannot be violated at all.
      • There is no valid road segment within the maximum distance (maximumDistanceToSegment default 50 km).
      • There is no route at all between start and destination, e.g. start in Europe, destination in USA.
      • With routing type conventional the levelling heuristic can cause that certain routes cannot be found.
  • For relations that can only be calculated with a route violation
    • The flag violated is set to true.
