Specify the language in FeatureLayers
Posted: Thu Sep 24, 2015 6:43 am
we would like to get the TruckAttributes and TrafficIncidents in a specific language.
Therefore, we have set the language property of the common element in the XMapProfile.
But the ToolTips of the Traffic Incidents and Truck Attributes are not returned in the specified language!
We are using the following code to add a Truck attribute layer:
And we have used the following code to add a Traffic Incident layer in the language of Italy:
I believe the ToolTips of the TruckAttributes layer should be translated by the MapLocalizer.GetString(MapStringId id)(, which does not work in our case. Because the Ptv.XServer.Controls.Map.dll consists the english language in Ptv.XServer.Controls.Map.Resources.Strings.resources.
And the Traffic messages are returned in the wrong language by the xMap Server.
Martin
var truckAttributesLayer = new XMapLayer("TruckAttributes", xmapMetaInfo.Url, xmapMetaInfo.User, xmapMetaInfo.Password) {
CustomCallerContextProperties = new xserver.CallerContextProperty[] {
new xserver.CallerContextProperty {
key = "ProfileXMLSnippet",
value = "<?xml version='1.0' encoding='us-ascii'?><Profile xmlns:xsi='http://www.w3.org/2001/XMLSchema-instance'><Common language='it' majorVersion='1' minorVersion='0' /><FeatureLayer majorVersion='1' minorVersion='0'><GlobalSettings enableTimeDependency='true' /><Themes><Theme id='PTV_TrafficIncidents' priorityLevel='0' /><Theme id='PTV_TruckAttributes' enabled='true' priorityLevel='0' /><Theme id='PTV_RestrictionZones' enabled='true' priorityLevel='0' /><Theme id='PTV_SpeedPatterns' enabled='true' priorityLevel='0' /></Themes></FeatureLayer></Profile>"
CustomXMapLayers = new xserver.Layer[] {
new xserver.FeatureLayer {
name = "PTV_TruckAttributes",
visible = true,
objectInfos = xserver.ObjectInfoType.REFERENCEPOINT
var trafficLayer = new XMapLayer("Traffic", xmapMetaInfo.Url, xmapMetaInfo.User, xmapMetaInfo.Password) {
value = "<?xml version='1.0' encoding='us-ascii'?><Profile xmlns:xsi='http://www.w3.org/2001/XMLSchema-instance'><Common language='it' majorVersion='1' minorVersion='0' /><FeatureLayer majorVersion='1' minorVersion='0'><GlobalSettings enableTimeDependency='true' /><Themes><Theme id='PTV_TrafficIncidents' enabled='true' priorityLevel='0' /><Theme id='PTV_TruckAttributes' priorityLevel='0' /><Theme id='PTV_RestrictionZones' priorityLevel='0' /><Theme id='PTV_SpeedPatterns' priorityLevel='0' /></Themes></FeatureLayer></Profile>"
new xserver.SMOLayer() {
name = "traffic.ptv-traffic",
objectInfos = xserver.ObjectInfoType.REFERENCEPOINT,
visible = true
MaxRequestSize = xmapMetaInfo.MaxRequestSize
Martin
