Restrictions because of Truck-Attributes, Time & Traffic
clvo
Post by clvo »
Hello everyone,
We have received a request from a customer to consider the following points in the context of route optimisation:
  • Traffic (historical and/or live)
  • Restrictions (lorry is too high/heavy for the road)
  • Emission zones (EURO5 lorries are not allowed to drive here)
  • Public time slots (access to pedestrian zone only from 6 - 8 a.m.)
Unfortunately, I didn't really find what I was looking for via the API or the forum (only with regard to traffic > as I read it, it's not possible).
Basically we can use one of the following:
  • Route Optimisation API
  • Route Optimisation Optiflow API
Thank you very much!
BR Claus
Re: Restrictions because of Truck-Attributes, Time & Traffic
Hello Claus,
in the Optimization APIs the flexibility of the underlying routing matrices is usually limited:
  • Users can choose the vehicle profile from a given set of available standard profiles which all support high performance routing for fastest dima calculation.
  • Therefore overriding vehicle properties such as physical dimensions or emission classes is not possible (at least of now) in the standard cloud services.
  • In the Route Optimization OPTIFLOW API you can benefit from the vehicle's traffic mode if your base profile supports it.
  • In the VRP Solver based APIs "PTV Route Optimization" and "PTV Sequence Optimization API" (both in maintenance mode!) the profiles are based on static, time-independent graphs. Therefore these two APIs do not support time dependency on the same level as the OPTIFLOW API does.
Please get back to us 1:1 so we might discuss how to get best quality for your users requirements.
