How to handle scientific representations?
Some SAP driven parties seem to struggle with the double values returned by our services (happens in xServer and Developer, e.g. within geocoding), (e.g. Greenwich) when they are formatted in the scientific style:
"roadAccessCoordinate": {
          "x": 7.0078042365E-05,
          "y": 51.484439867
        "address": {
          "country": "United Kingdom",          "state": "England",          "province": "London",
          "postalCode": "SE10 9NY",         "city": "London",          "district": "Greenwich",
          "subdistrict": "",          "street": "Old Woolwich Road",          "houseNumber": "78"
Well - here's some advice from the internet:
To enable an SAP system (like SAP ABAP) to parse a scientific notation value (e.g., `1.23E+02` for `123`) from a JSON response and transform it into a Double, you can apply these strategies:
  1. Parse the JSON Response in ABAP
    If you have the JSON response directly in ABAP, you can use a JSON parser to read it. In SAP ABAP, classes like `CL_TREX_JSON_PARSER` (for older versions) or `CL_SXML_JSON_READER` (in newer versions) are available for JSON parsing.
  2. Extract the Scientific Notation Value as a String
    The scientific notation value in JSON is typically stored as a string. Read this string into an ABAP variable, such as `lv_scientific`.
  3. Convert the String to a Double Value
    ABAP supports converting scientific notation to numeric types like `FLOAT` (double). To achieve this, you can use the `CONV` or `VALUE` statements.
    Here’s an example:
    ```abap
    DATA: lv_scientific TYPE string VALUE '1.23E+02', " Example value
    lv_double TYPE f. " FLOAT type in ABAP
    " Convert the scientific notation string to Double (FLOAT)
    lv_double = CONV f( lv_scientific ).
    " Display result
    WRITE: / 'The double value is:', lv_double.
  4. Example with JSON Parsing
    If you have a JSON response that includes the scientific notation value, you can parse it and convert it to a double value as shown below:
    ```abap
    DATA: json_string TYPE string VALUE '{"value": "1.23E+02"}', " Example JSON
    json_reader TYPE REF TO cl_sxml_json_reader,
    lv_value TYPE string,
    lv_double TYPE f.
    " Instantiate JSON parser
    CREATE OBJECT json_reader
    EXPORTING
    json = json_string.
    " Extract the value
    json_reader->next_node( ).
    json_reader->get_value( RECEIVING value = lv_value ).
    " Convert the value to Double
    lv_double = CONV f( lv_value ).
    " Display result
  5. Important Notes
    - The `f` type in ABAP is equivalent to a Double (64-bit floating-point), which supports scientific notation.
    - If the scientific notation is not processed correctly, ensure it is in a valid format. SAP ABAP expects the notation to be in the form `1.23E+02`, where the letter "E" is uppercase.
    With this approach, you should be able to transform scientific notation values from a JSON response into a double value in SAP ABAP.
MISTERX
Re: How to handle scientific representations?
Post by MISTERX »
Hello Bernd!
First of all, I would like to confirm the solution you have provided. It is detailed and complete - thank you for that!
In addition, I would like to refer to a post of mine in this forum in which I have dealt with the coordinate formats of the xServer and the PTV-Developer. This may be of interest to others: Available Coordinate Formats
Mr. X
  • Integration PTV <> SAP
  • Senior Consultant
