VehicleParameter
Gasper
VehicleParameter
Post by Gasper »
How come there is no VehicleParameter in xTour? In xRoute you can specify vehicle type (car, van, truck ...) is there some other way?
Re: VehicleParameter
Hello Gasper,
while you may specify each routing parameter of a vehicle in xRoute via the so-called UPM (unified profile mechanism) as a part of CallerContext (more precise CallerCOntextProperty."XMLProfileSnippet") the xTour does not support this kind of API injection.
This means that you have to specify each required routing parameter set as a server-side profile. Once such a server-side profile is available you may refer to it via the DistanceMatrix "profile" name. Ideally a search graph is available on server side (matching the XML profile) so the HighPerformanceRouting may take effect.
Let me know if you need further info,
