PTV Developer / Routing API - how to determine distance per country?
Posted: Mon Feb 05, 2024 4:49 pm
I've been asked how I'd recommend to compute the "distance per country" in a PTV Developer Routing API client application (as this info is not native part of the response).
Here's my approach - based on Border_Events and Waypoint_Events.
Feedback is welcome - especially if you detect an error
// for a proper aggregation of country-wise data we need to use BORDER_EVENTS and WAYPOINT_EVENTS
if ((results.Contains(Routing.Model.Results.BORDER_EVENTS)) && (results.Contains(Routing.Model.Results.WAYPOINT_EVENTS)))
Dictionary<string, double> dictDistancePerCountry = new Dictionary<string, double>();
List<Routing.Model.Event> lstWaypointEvents = lstEvents.Where(ev => ev.Waypoint != null).ToList();
Routing.Model.Event firstWaypoint = lstWaypointEvents.First(), lastWaypoint = lstWaypointEvents.Last();
// convenience method : in some countries like "US" we use a combined string such as "US-CA" to refer to a subunit.
string getCountry(Routing.Model.Event ev)
return ev.CountryCode.Split('-')[0];
// are there any border crossings?
if (lstEvents.Any(ev => ev.Border != null))
List<Routing.Model.Event> lstBorderEvents = lstEvents.Where(ev => ev.Border != null).ToList();
Routing.Model.Event firstBorder = lstBorderEvents.First() , lastBorder = lstBorderEvents.Last();
dictDistancePerCountry.Add(getCountry( firstWaypoint ), firstBorder.DistanceFromStart);
double lastPart = lastWaypoint.DistanceFromStart - lastBorder.DistanceFromStart;
if (dictDistancePerCountry.ContainsKey(getCountry( lastBorder)))
dictDistancePerCountry[getCountry(lastBorder)] += lastPart;
else
dictDistancePerCountry.Add(getCountry(lastBorder), lastPart);
for (int index = 1; index < lstBorderEvents.Count; index++)
double leg = lstBorderEvents[index].DistanceFromStart - lstBorderEvents[index - 1].DistanceFromStart;
string country = getCountry(lstBorderEvents[index-1]);
if (dictDistancePerCountry.ContainsKey(country))
dictDistancePerCountry[country] += leg;
else
dictDistancePerCountry.Add(country, leg);
else // no border crossings
dictDistancePerCountry.Add(getCountry(lastWaypoint), lastWaypoint.DistanceFromStart);
// visualization of aggregates.
chartRouting_CustomAGgregates_DistancePerCountry.Series.First().Points.Clear();
foreach (string key in dictDistancePerCountry.Keys)
string label = "Country=" + key + "\r\ndistance=" + Tools.displayDistance(dictDistancePerCountry[key], routeResponse.Distance);
DataPoint dataPoint = new DataPoint {
ToolTip = label,
Label = label,
YValues = new double[] { dictDistancePerCountry[key] }
chartRouting_CustomAGgregates_DistancePerCountry.Series.First().Points.Add(dataPoint);
foreach (DataPoint dp in chartRouting_CustomAGgregates_DistancePerCountry.Series.First().Points)
dp.Color = System.Drawing.Color.FromArgb(128,dp.Color);
dgvRouting_CustomAGgregates_DistancePerCountry.DataSource = dictDistancePerCountry.Keys.Select(k => new {
k,
distance = dictDistancePerCountry[k],
RelativeDistance = Tools.displayDistance(dictDistancePerCountry[k], routeResponse.Distance)
}).ToArray();
