xLocate2 Cyrillic vs Latin
Posted: Fri Dec 08, 2023 1:06 pm
by RemcoZut
We encounter a problem with the xServer2 XLocate responses on countries where cyrillic script is default.
The use-case:
- SearchLocationRequest is invoked with mapLanguage with 'nl' (dutch) or other western languages.
- When the requested language is not available in the map data the language of the country locality is used.
- In case of requesting the Sparta in Greece this results in a western human unreadable cyrillic 'Σπάρτη'
- A western Latin value was expected like 'Sparti'
- To ensure latin script a workaround is implemented which checks the requested country and overrides the preferred mapLanguage when in certain cyrillic based countries with resp und-Latn-t-el, und-Latn-t-ru.
- Unfortunately this workaround doesn't cover all types of requests, ie:
- a searchByText without allowedCountries specification
- a searchByPosition without allowedCountries specification (which definitely is the common way to be invoked, agree?)
An improvement in the xServer can be to have a switch in xserver.conf to enforce Latin script in the output
A related topic is
viewtopic.php?t=1595
Kind regards,
Remco Zut | Locatienet bv
Re: xLocate2 Cyrillic vs Latin
Posted: Fri Dec 08, 2023 2:52 pm
Hi Remco,
not sure what the request is about... you want to enforce a "latin" version of an output?
Code: Select all {
"$type":"SearchByTextRequest",
"text": "Greece,Sparta",
"requestProfile": {
"mapLanguage": "nl"
Code: Select all {
"requestProfile": {
"mapLanguage": "und-Latn-t-el"
Code: Select all {
"requestProfile": {
Code: Select all {
"$type": "LocationsResponse",
"results": [
"location": {
"referenceCoordinate": {
"x": 22.426630091,
"y": 37.074611685
"address": {
"country": "Griekenland",
"state": "Πελοπόννησος",
"province": "Λακωνία",
"city": "Σπάρτη"
"formattedAddress": "Σπάρτη"
"matchQuality": {
"totalScore": 100,
"addressScores": {
"country": 100,
"state": 0,
"province": 0,
"city": 100
"type": "LOCALITY"
Code: Select all {
"results": [
"location": {
"x": 22.426630091,
"y": 37.074611685
"address": {
"country": "Ellada",
"state": "Peloponnisos",
"province": "Lakonia",
"city": "Sparti"
"formattedAddress": "Sparti"
"matchQuality": {
"totalScore": 100,
"addressScores": {
"country": 100,
"state": 0,
"province": 0,
"city": 100
"type": "LOCALITY"
| Code: Select all {
"results": [
"location": {
"x": 22.426630091,
"y": 37.074611685
"address": {
"country": "Ελλάδα",
"city": "Σπάρτη"
"matchQuality": {
"totalScore": 100,
"addressScores": {
"country": 100,
"state": 0,
"province": 0,
"city": 100
"type": "LOCALITY"
Posted: Wed Dec 13, 2023 12:48 pm
by RemcoZut
The mapLanguage of our requests is usually 'nl'
"$type": "SearchByTextRequest",
"text": "Sparta",
"requestProfile": {
"mapLanguage": "nl"
which results in Cyrillc Greek:
"results": [
"location": {
"x": 22.426630091,
"y": 37.074611685
"address": {
"city": "Σπάρτη"
This is not readable for the end-user. Thus a Latin version is needed as a fallback mapLanguage.
Posted: Wed Dec 13, 2023 3:57 pm
Hi Remco,
currently this is not possible. But we forwarded the requirement to product management.
Please get in touch with Joost/Kasper, too.
Posted: Thu Dec 14, 2023 12:00 pm
by RemcoZut
They are already informed
Posted: Fri Sep 13, 2024 8:17 am
by RemcoZut
I want to actualize this issue.
For the geocoding request Valjevo in Servia with maplanguage Russian transliterated to latin alphabet (transformation subtag).
"$type": "SearchByAddressRequest",
"address": {
"city": "Valjevo",
"country": "RS"
"requestProfile": {
"mapLanguage": "und-Latn-t-ru"
The response is still in cyrillic notation, and thus unreadable for western human
"results": [
"location": {
"x": 19.890300695,
"y": 44.273788494
"address": {
"country": "Servia",
"state": "Централна Србија",
"province": "Колубарски Округ",
"city": "Ваљево"
"formattedAddress": "Ваљево"
"matchQuality": {
"totalScore": 100,
"addressScores": {
"country": 100,
"state": 0,
"province": 0,
"city": 100
"type": "LOCALITY"
I understand that this is because of the lack of availability, as stated in the documentation:
It depends on the data whether or not texts are available in the requested language. If the requested language is not available for that item, the default text will be used
But the map of Valjevo in Servia is showing the name of the city in latin correctly. So you may think the lating version should be available.
For example run this
var map = new L.Map('map', { center: [44.273788494,19.890300695], zoom: 10 });
// Add a tile layer with the url pattern.
var tileUrl = xServerUrl + '/services/rest/XMap/tile/{z}/{x}/{y}';
new L.TileLayer(tileUrl, { minZoom: 1, maxZoom: 19}).addTo(map);
At:
https://xserver2-europe-eu-test.cloud.p ... 257C_____1
Can you please tell me why the map is showing the city in correct latin and the geocoder doesn't
Kind regards,
Remco Zut
Locatienet
Posted: Mon Sep 16, 2024 2:33 pm
Hi Remco,
in the upcoming version of xLocate (v2.34, expected for mid/end of october) we will also support "
x-ptv-Latn-DFT" which will then return the result as expected.
This value is already supported in PTV Developer:
"country": "RS", "state": "", "locality": "Valjevo",
"postalCode": "", "street": "", "houseNumber": "",
"countryFilter": null, "language": "x-ptv-Latn-DFT",
"results": [
"ADDRESS_SCORES"
returns:
"locations": [
"locationType": "LOCALITY",
"referencePosition": {
"latitude": 44.273788452148438, "longitude": 19.890300750732422
"address": {
"countryName": "Srbija", "state": "Centralna Srbija",
"province": "Kolubarski Okrug", "postalCode": "",
"city": "Valjevo",
"district": "", "subdistrict": "",
"countryCodeIsoAlpha2": "RS",
"countryCodeIsoAlpha3": "SRB"
"formattedAddress": "Valjevo",
"quality": {
"distance": null,
"totalScore": 100,
"addressScores": {
"country": 100,
"city": 100
Posted: Mon Feb 16, 2026 8:24 am
here's another example:
also check
Technical Concepts - Geocoding - Language Codes
"text": "Istanbul",
"requestProfile": {
"mapLanguage": "x-ptv-Latn-DFT"
returns:
"results": [
{ "location": { "referenceCoordinate": { "x": 28.988769609, "y": 41.062011728 },
"address": { "country": "Türkiye","state": "Istanbul","province": "Sisli", "city": "Istanbul"
}, "formattedAddress": "Istanbul" },
"matchQuality": { "totalScore": 100,"addressScores": {"country": 0,"state": 0, "province": 0, "city": 100 }
"type": "LOCALITY"
