xServer 2.31 released
Posted: Mon Dec 04, 2023 1:30 pm
There it is - xServer 2.31 is available...
Engins ia available for download at the Customer Area
Check the release history in XSI 2 Test...xServer 2.31.0
generalxdata
- Improvement: Empty geometries in all encodings (Plain, WKB, WKT, KML, GeoJSON) are supported for request and response fields.
- Improvement: Updated the Apache Tomcat.
- Improvement: Updated several third-party components.
- Bugfix: Incompatible detailed toll updates via PTV Content Update Service are completely rejected and have no impact on results.
- Bugfix: Fixed the product name for detailed toll as the product name for basic toll was internally used by mistake (see property 'core.contentupdates.content.detailedToll.productName' in the xServer configuration file).
- Bugfix: Fixed unexpected reloads when using dynamic pages of the dashboard like Raw Request Runner or API Changes.
xdima
- Improvement: The fields 'referenceTimes' in the type 'SegmentsOptions' and 'timeZones' in the type 'MapSegment' are no longer experimental.
- Improvement: The field 'mapVersion' in the type 'FeatureLayerDescription' is no longer experimental.
xload
- Feature: Added support to consider low emission zones in different European countries. Please note that this is experimental and requires the new Feature Layer 'PTV_LowEmissionZones' available from the PTV World City Map 2024.2H.
- Feature: Added field 'seasonalClosurePenalty' to the type 'SpecialAreas' of the routing profile to avoid seasonal closures like mountain passes.
- Improvement: The field 'co2EmissionClassEU' in the type 'Engine' of the vehicle profile is no longer experimental.
- Bugfix: Toll roads for electric trucks in Germany are no longer avoided by ignoring toll sections with price 0.
xroute
- Feature: Added field 'stackOnTopOfNextStops' to the type 'StackingOptions' to stack items of a stop above items of the next stops in case of using an unloading sequence.
- Bugfix: When planning items with a forbidden orientation 'original', it is ensured that this orientation is not part of the result.
xruntime
- Feature: Added country-specific low emission zones stickers like 'DE_NONE' or 'FR_NONE' to prohibit all zones of the corresponding country.
- Improvement: The performance of using custom Feature Layers especially for long routes is improved when no preferred route types are included.
- Improvement: It is now possible to use the parameter 'simplifiedRouteCalculation' of the exact time consideration modes in combination with using a path waypoint.
- Bugfix: Custom Feature Layers used in a stored profile are always considered.
- Bugfix: Fixed bug when the start time of the service at a waypoint was one second before the start of the opening interval.
- Bugfix: Fixed bug when returning straight and not detailed polylines of boat and rail connections in some rare cases.
- Bugfix: Removed duplicate result limitations on misconfigured vehicle when using vehicle parameters at waypoints.
- Bugfix: The total service time of the tour report is correctly calculated and no waiting time is included.
- Bugfix: The tour event of type 'WAITING' is removed in case there is another tour event of type 'BREAK' present in parallel.
- Bugfix: The missing maneuver events of type 'ARRIVE', 'ARRIVE_LEFT' and 'ARRIVE_RIGHT' are present at all intermediate waypoints.
- Bugfix: Fix handling of service period exceeding the maximum time between breaks and rests in driving time regulations.
subdivisions.
- Feature: Added field 'name' to the types 'Country' and 'Subdivision' of the operation 'getDataInformation' to provide the names of countries and
xtour
- Feature: Added support for using EU working time directive in combination with EU driving time regulation. When using both regulations, break splits are enabled.
