xServer 2.31 released
There it is - xServer 2.31 is available...
xServer 2.31.0
general
  • Improvement: Empty geometries in all encodings (Plain, WKB, WKT, KML, GeoJSON) are supported for request and response fields.
  • Improvement: Updated the Apache Tomcat.
  • Improvement: Updated several third-party components.
  • Bugfix: Incompatible detailed toll updates via PTV Content Update Service are completely rejected and have no impact on results.
  • Bugfix: Fixed the product name for detailed toll as the product name for basic toll was internally used by mistake (see property 'core.contentupdates.content.detailedToll.productName' in the xServer configuration file).
  • Bugfix: Fixed unexpected reloads when using dynamic pages of the dashboard like Raw Request Runner or API Changes.
xdata
  • Improvement: The fields 'referenceTimes' in the type 'SegmentsOptions' and 'timeZones' in the type 'MapSegment' are no longer experimental.
  • Improvement: The field 'mapVersion' in the type 'FeatureLayerDescription' is no longer experimental.
xdima
  • Feature: Added support to consider low emission zones in different European countries. Please note that this is experimental and requires the new Feature Layer 'PTV_LowEmissionZones' available from the PTV World City Map 2024.2H.
  • Feature: Added field 'seasonalClosurePenalty' to the type 'SpecialAreas' of the routing profile to avoid seasonal closures like mountain passes.
  • Improvement: The field 'co2EmissionClassEU' in the type 'Engine' of the vehicle profile is no longer experimental.
  • Bugfix: Toll roads for electric trucks in Germany are no longer avoided by ignoring toll sections with price 0.
xload
  • Feature: Added field 'stackOnTopOfNextStops' to the type 'StackingOptions' to stack items of a stop above items of the next stops in case of using an unloading sequence.
  • Bugfix: When planning items with a forbidden orientation 'original', it is ensured that this orientation is not part of the result.
xroute
  • Feature: Added country-specific low emission zones stickers like 'DE_NONE' or 'FR_NONE' to prohibit all zones of the corresponding country.
    SeasonalClosures: new segment attribute and impact...
  • Improvement: The performance of using custom Feature Layers especially for long routes is improved when no preferred route types are included.
  • Improvement: It is now possible to use the parameter 'simplifiedRouteCalculation' of the exact time consideration modes in combination with using a path waypoint.
  • Bugfix: Custom Feature Layers used in a stored profile are always considered.
  • Bugfix: Fixed bug when the start time of the service at a waypoint was one second before the start of the opening interval.
  • Bugfix: Fixed bug when returning straight and not detailed polylines of boat and rail connections in some rare cases.
  • Bugfix: Removed duplicate result limitations on misconfigured vehicle when using vehicle parameters at waypoints.
  • Bugfix: The total service time of the tour report is correctly calculated and no waiting time is included.
  • Bugfix: The tour event of type 'WAITING' is removed in case there is another tour event of type 'BREAK' present in parallel.
  • Bugfix: The missing maneuver events of type 'ARRIVE', 'ARRIVE_LEFT' and 'ARRIVE_RIGHT' are present at all intermediate waypoints.
  • Bugfix: Fix handling of service period exceeding the maximum time between breaks and rests in driving time regulations.
xruntime
  • Feature: Added field 'name' to the types 'Country' and 'Subdivision' of the operation 'getDataInformation' to provide the names of countries and
subdivisions.
xtour
  • Feature: Added support for using EU working time directive in combination with EU driving time regulation. When using both regulations, break splits are enabled.
Check the release history in XSI 2 Test...
Engins ia available for download at the Customer Area
ajg
Re: xServer 2.31 released
Post by ajg »
I tried installing xServer 2.31 today on Windows Server 2012, and had difficulties running it.
When loading the 'modules' it was failing with error 50:
boost_log-vc142-mt-x64-1_83.dll: can't find dependent libraries
There is no mention anywhere (that I could find) to say that there are dependencies for xServer 2.31 apart from Java 17.
I solved my issue by installing 'Microsoft Visual C++ 2015-2022 Redistributable Version (x64)'.
Do you know when this became a dependency? The last installation on this server was xServer 2.27 with Java 8.
I think it would be a good idea to add this dependency to the Release Notes and also the Installation Instructions.
Andrew Gibbons
PTV Logistics (APAC / UK)
Andrew Gibbons
Software Developer (Product Integration)
PTV Group Australia
Hi Andrew,
looks like you have been running into this topic which was dropped in the PTV xServer Admin forum (visible after login).
The first time I heard of this issue was in fact when v2.31 was installed at several partner's environments. I like the idea of adding such important feedback to the INFO stream announcement of a new version ;-) I'll keep this in mind.
:!: From a generic perspective I recommend that you also use the forum's search function (logged in!). Especially when you encounter an error message: I want to add each and every error message that was reported including a solution to the forum so our users can find the missing info.
If you prefer to contact a PTV support team you will get the solution, too - but on that channel the community won't be able to find it in the open space ;-)
