blockings: segment direction versus driving directions
Hello together,
these days a prospect asked me about the difference between some specific segment attributes he found in the RoadEditor / TruckAttributes. In the output of his routes he found the following two values:
  • MAX_AXLE_LOAD|0=1150
  • MAX_AXLE_LOAD|1=1150
Looks like this info is missing in the 1.20 documentation so this is why I'd like to reslove it:
The bold digit simply describes the segment direction to which the attribute refers...
It is important to know that each segment is stored in an oriented way with a START and a DESTINATION
See the following screenshots... If a segment restriction is applied in both directions it is labelled with a 2 - and therefore displayed without direction arrows:
WEIGHT-Restriction applied in both directions
If the restriction is only one direction we use the values 0 and 1 to separate the direction:
HAZARDOUS_GOODS restriction in one direction (destination to start)
HAZARDOUS_GOODS 0=1.gif (8.78 KiB) Viewed 5337 times
TRUCK RESTRICTION in one direction (start to end)
In the context of mapping we refer to the data direction used in the binary map data.
In the context of routing and the label as a ROADEDITOR_ADDITIONAL_OPTION (output of routing request) we refer to the driving direction.
The following routing screenshots have been made with TRUCK profiles...
If the route is calculated against the restriction we are allowed to use the segments.
Trying to drive in the direction of the blocking is not allowed and so we take a detour.
Driving from south to north by car doesn't require a detour as the restriction is for trucks only - even in case of "in driving direction".
I hope these screenshots explain the meaning ;-)
Regards Bernd
PS
ATTRIBUTES north to south
SOUTH to NORTH attributes truck
