Log requests within client application based on PTV sdk (Java)
These days a partner asked us how to log the requests and responses from within an application that uses client classes shipped by PTV.
Now here's some piece of code provided by DEV (Thanks, Ralf!). The logging of request and response bodies can be achieved by using this snippet to create the xServer client in Java (xserver-java-openapi.client / JSON):
import com.microsoft.rest.LogLevel;
import com.microsoft.rest.RestClient;
import com.microsoft.rest.ServiceResponseBuilder;
import com.microsoft.rest.serializer.JacksonAdapter
import com.ptvgroup.xserver.XServer
static void setUp() {
    RestClient restClient = new RestClient.Builder()
            .withBaseUrl(<replace_with_your_server_base_url>)
            .withResponseBuilderFactory(new ServiceResponseBuilder.Factory())
            .withSerializerAdapter(new JacksonAdapter())
            .withLogLevel(LogLevel.BODY)
            .build();
    xServerApi = new XServerImpl(restClient);
:!: Assert that your runtime has sl4j and and a logger impl like log4j2. You also need a logging config in your classpath. For log4j2 I used this log4j2.xml to log to console:
<Configuration status="WARN">
    <Appenders>
        <Console name="Console" target="SYSTEM_OUT">
            <PatternLayout pattern="%d;%p;%C{2}::%M[%L];%m%n" />
        </Console>
    </Appenders>
    <Loggers>
        <Root level="WARN">
            <AppenderRef ref="Console"/>
        </Root>
        <Logger name="com.ptvgroup.xserver" level="INFO" additivity="false">
        </Logger>
    </Loggers>
</Configuration>
