xServer 2.28 released
Posted: Mon Feb 06, 2023 9:47 am
PTV proudly presents: PTV xServer 2.28...
The PTV xServer 2.28 is released! Main reason is the Java 17 support, which is the latest Java LTS (Long-Term-Support) version. Please note that Java 8 is no longer supported. As Java is not integrated in the PTV xServer, you have to install Java 17 separately. And there are two additional highlights:
xCluster
  • Support of Gurobi as standard optimization solver to improve the planning results
xRoute
  • Support of restricted road sections in Austria ("Ziel- und Quellverkehr", data available in the HERE maps from 2023.2H on)
xTour
  • Performance improvements
  • Quality improvements
The PTV Content Update Service 2.28 is also available and supports Java 8 and Java 17. It is still possible to run PTV xServer 1 (Java 8) and 2 (Java 17) on the same system as you can set an additional environment variable like 'XSERVER1_JAVA_HOME' to the Java 8 path.
The on-premise solution can be found here: The cloud solution PTV xServer internet will be updated according to this plan:
  • 21.02.23: Productive system hosted in Europe
  • 22.02.23: Productive system hosted in US
  • 23.02.23: Productive system hosted in Australia
Please ensure to look into this article about the usage of different Java runtimes.
Thanks to Haba for the input,
