xServer 2.28 released
PTV proudly presents: PTV xServer 2.28...
The PTV xServer 2.28 is released! Main reason is the Java 17 support, which is the latest Java LTS (Long-Term-Support) version. Please note that Java 8 is no longer supported. As Java is not integrated in the PTV xServer, you have to install Java 17 separately. And there are two additional highlights:
xCluster
  • Support of Gurobi as standard optimization solver to improve the planning results
xRoute
  • Support of restricted road sections in Austria ("Ziel- und Quellverkehr", data available in the HERE maps from 2023.2H on)
xTour
  • Performance improvements
  • Quality improvements
The PTV Content Update Service 2.28 is also available and supports Java 8 and Java 17. It is still possible to run PTV xServer 1 (Java 8) and 2 (Java 17) on the same system as you can set an additional environment variable like 'XSERVER1_JAVA_HOME' to the Java 8 path.
The on-premise solution can be found here: The cloud solution PTV xServer internet will be updated according to this plan:
  • 21.02.23: Productive system hosted in Europe
  • 22.02.23: Productive system hosted in US
  • 23.02.23: Productive system hosted in Australia
Please ensure to look into this article about the usage of different Java runtimes.
Thanks to Haba for the input,
Release Notes 2.28
Release Notes 2.28
