Accept gzipped JSON requests
tadam
Post by tadam »
In the Xserver2 documentation you mention that "The PTV xServer will accept compressed requests and send compressed responses".
The response compression works succesfully if we set Accept-Encoding header with gzip value.
The problem is the other direction, if we send a gzipped json request to "/services/rs/XRoute/calculateRoute" with Content-Encoding: gzip we get the following error:
    "message": "Illegal character ((CTRL-CHAR, code 31)): only regular white space (\\r, \\n, \\t) is allowed between tokens\n at [Source: (org.apache.cxf.transport.http.AbstractHTTPDestination$1); line: 1, column: 2]",
    "errorLine": 1,
    "errorColumn": 2,
    "faultType": "com.ptvgroup.xserver.exceptions.InvalidRequestFault"
Could you help us to solve this issue? May we miss a config somewhere?
It would be a great improvement for us if this worked, becouse we very often send large requests with RequestProfile or binaryFTL.
Thanks,
Adam
Re: Accept gzipped JSON requests
Hello Adam,
honestly spoken I always managed to use some frameworks to create my client classes without the need to dig into the message assemblage by myself. But I would love to assist.
The error message blames a specific character : ascii control character 31 also known as "unit separator". I searched for it and found this wikipedia article.
The character seems to be reserved for some purpose that is an obstacle in your context. How do you assemble the request body? What framework do you use? Can you trace the exact message on the server's logs? Do you use some "database export" structure to create the content?
I also looked for the error message and found another article that mentions that code sequences have to be escaped when being included in a body. Maybe this helps?
Another hint from DEV (thanks, Mathias H.!):
https://www.predic8.com/gzip-compression-filter.htm
tadam
Post by tadam »
This servlet filter works as expected!
Thanks for your help!
