Best practices : gather toll as quick as possible
Posted: Mon Dec 13, 2021 5:13 pm
Cheers,
from time to time I get asked how to gather the toll prices for a relation A:B as quick as possible. Users try to apply which seem to be promising to them but from my perspective I recommend to take care of the following constraints:
- Some countries apply toll based on the time of the day. To gather such contributions properly you need to apply a proper time dependency aka TimeConsiderationMode, e.g. SNAPSHOT or ExactTimeConsiderationAtStart or ExactTimeConsiderationAtArrival.
If you apply no such mode or Optimistic you may loose contributions. - If a time consideration mode is applied you can probably not benefit from HighPerformanceRouting but have to use RoutingType=CONVENTIONAL. (
Though HPR supports Optimistic and Snapshot there are no such graphs available in the XSI cloud). - Do not forget to activate the proper feature layers such as PTV_TruckAttributes and PTV_TruckSpeedPatterns (or PTV_SpeedPatterns). Keep in mind that each additional feature layer has a negative impact on the performance. In my opinion the SpeedPatterns might not be helpful on long distance relations.
If you do not use HPR you might activate the GeographicRestriction with automatic search space bounds.
