Performance of KEP usecase
Cheers,
I've been asked about the performance of a sequencing usecase (KEP to be more precise). Well, the answer is not that simple so I decided to write this forum post. I'll start with an assumption and also mention some factors with impact on performance.
Here's the story:
Imagine the requirement is to optimize a sequence of 100 parcels supposed to be delivered in an urban area. A single vehicle is used
Under the roof the usecase is splitted into several steps:
  • DistanceMatrix calculation
    • Best case: the DIMA is already available (or AIRLINE is sufficient) : 0 seconds
    • Average case: DIMA is supposed to be calculated based on HPR : <2 seconds
    • Worst case: No DIMA available, time dependency applies, conventional approach... : could take 10 seconds or more
    • PS: the performance boost we achieve in DIMA calculation is getting bigger with the size of the distance matrices. For very small distance matrices (e.g. <10²) you may encounter a stable overhead when you use the cloud based services. This is because of some network latency and internal file handling on the shared space in Azure ;-) For larger sizes you would not recognize this overhead compared to the overall calculation time.
  • Optimization via the core algorithm (VRP solver)
    • Best case: performance mode, pure sequence (no constraints, no unscheduled orders): < 1 second
    • Medium case: < 5 seconds
    • Worst case: many, many time window constraints: 10 seconds
  • The routing:
    • Best case: not required (no visualization): 0 seconds
    • Medium case: simple route, no time dependency: 1 sec
    • Worst case: time dependency, no search graph available...: 3-5 seconds
  • Visualization / Mapping
    • Best case: no visualization needed: 0 seconds
    • Medium case: cache available, small image size: <1 second
    • Worst case: large screen, no cache: about 2-5 seconds
As mentioned above there are many factors with an impact on performance:
  • On Premise versus cloud service
  • xDima: DIMA available or not?
  • xDima/xRoute: time dependency needed?
  • xDima/xRoute: geographic area
  • xDima/xRoute: HPR possible?
  • xTour: structure of time window constraints
  • xTour: Performance versus Quality
  • xTour: AvoidOverlap
  • xRoute: result fields - each requested element raises computation time and network latency due to increased response size
  • xMap: Display size (number of tiles) - cache available
List is subject to grow ;-) Feedback is welcome!
