Migration Helpdesk portal
Hi everyone,
many of you are familiar with the Old PTV Support portal which is available at https://helpdesk.ptvgroup.com/
Your old content (Tickets with the ID PTV2_____) is still available in the old environment. :!: Sooner or later this old portal will be disabled!
As some of you already noticed: PTV has set up a New PTV Helpdesk portal which is available at https://support.ptvgroup.com/ If you want to create new tickets you need to use the new portal and create a new account over there. New tickets will get an ID starting with "PTV3_____".
Notification at the old helpdesk portal. Your content is safe.
Questions? Get back to your technical PTV counterpart,
