Hello everyone,
I'm trying to help a custumer doing interactive stuff with ajaxmaps and I would share with you my considerations. The feature is to drag some points (orders or clients) on the map and drop them in an already drawn tour (polyline).
Obviously the business logic will check whether the orders are compatible with the selected tour and so on, my effort, at the moment, is to provide a method that intercepts the second click (drop) and establish the nearest tour (within a tollerance). Having the n-points and the tour will be easy to code a method that puts the orders inside the tour, if it is feasible. Do you have any suggestion about this? It would be nice to have a look to some code if you even had done it.
Thanks to all!
Dan
drag and drop (orders into a tour)
Re: drag and drop (orders into a tour)
Hello Daniele,
I'll forward your request to some developers... as far as I know them they'll answer quick.
AndreasJunghans
Hi Daniele,
here's a tutorial sample for creating selectable and draggable elements that can be dropped on each other (including lines). It consists of a custom marker class (for selectable and draggable icons), a custom line class (for selectable lines that can serve as drop targets) and a VectorLayer subclass to handle drag-and-drop events.
Andreas
Andreas
<!DOCTYPE html>
<html>
<head>
<!--[if IE]>
<script type="text/javascript" src="webcomponent/script/excanvas.js"></script><![endif]-->
<script type="text/javascript" src="webcomponent/script/qooxdoo/script/qx-transport.js"></script>
<script type="text/javascript" src=".qxrpc"></script>
<script type="text/javascript" src="webcomponent/script/map.js"></script>
<script type="text/javascript">
// --> should be put into an external script
qxp.OO.defineClass("custom.IconElement",
com.ptvag.webcomponent.map.vector.AggregateElement,
function(x, y) {
com.ptvag.webcomponent.map.vector.AggregateElement.call(this);
var self = this;
var mImageMarker = null;
var mInfoBox = null;
// --> add other elements here if needed
var mShowingDropImage = false;
if (x != null) {
self.setX(x);
if (y != null) {
self.setY(y);
var createElements = function(vectorLayer) {
mImageMarker = new com.ptvag.webcomponent.map.vector.ImageMarker(
self.getX(), self.getY());
var VectorLayer = com.ptvag.webcomponent.map.layer.VectorLayer;
mImageMarker.setAlignment(VectorLayer.ALIGN_MID_HORIZ +
VectorLayer.ALIGN_MID_VERT);
self.addElement(mImageMarker);
// --> create other elements here if needed
setUrl();
self.dragOver = function(element) {
// return false if element can't be dropped here
mShowingDropImage = true;
setUrl();
return true;
self.dragOut = function(element) {
setUrl();
self.drop = function(element) {
alert("Dropped on element");
setUrl();
self.setOpacity = function(opacity) {
if (mImageMarker != null) {
mImageMarker.setOpacity(opacity);
if (opacity < 1) {
if (mInfoBox != null) {
self.removeElement(mInfoBox.getId());
mInfoBox = null;
} else if (self.getSelected() && mInfoBox == null) {
setUrl();
self._modifyX = function(propValue) {
mImageMarker.setX(propValue);
mInfoBox.setX(propValue);
// --> modify other elements here if needed
self._modifyY = function(propValue) {
mImageMarker.setY(propValue);
mInfoBox.setY(propValue);
var setUrl = function() {
var mNeedInfoBox = false;
if (mShowingDropImage) {
mImageMarker.setUrl(
"webcomponent/img/com/ptvag/webcomponent/map/button_reset.gif");
mNeedInfoBox = true;
} else if (self.getSelected()) {
"webcomponent/img/com/ptvag/webcomponent/map/button_zoom_in.gif");
} else {
"webcomponent/img/com/ptvag/webcomponent/map/button_zoom_out.gif");
if (mNeedInfoBox && mInfoBox == null) {
mInfoBox = new com.ptvag.webcomponent.map.vector.InfoBox();
mInfoBox.setX(self.getX());
mInfoBox.setY(self.getY());
mInfoBox.setText("Element info");
self.addElement(mInfoBox);
} else if (!mNeedInfoBox && mInfoBox != null) {
mInfoBox = null;
self._modifySelected = function(propValue) {
setUrl();
self.getSquareDistance = function(evt) {
var distX = evt.relMouseX - mImageMarker.getRealX();
var distY = evt.relMouseY - mImageMarker.getRealY();
var squareDist = distX*distX + distY*distY;
if (squareDist <= 12*12) {
// --> modify as needed for sensitivity
return squareDist;
return -1;
// overridden
var superModifyVectorLayer = self._modifyVectorLayer;
self._modifyVectorLayer = function(propValue) {
superModifyVectorLayer.apply(self, arguments);
if (propValue != null) {
createElements(propValue);
qxp.OO.addProperty({ name:"x", type:qxp.constant.Type.NUMBER, allowNull:false });
qxp.OO.addProperty({ name:"y", type:qxp.constant.Type.NUMBER, allowNull:false });
qxp.OO.addProperty({ name:"selectable", type:qxp.constant.Type.BOOLEAN,
allowNull:false, defaultValue:false });
qxp.OO.addProperty({ name:"selected", type:qxp.constant.Type.BOOLEAN,
qxp.OO.addProperty({ name:"draggable", type:qxp.constant.Type.BOOLEAN,
qxp.OO.defineClass("custom.LineElement",
function(lineCoords, infoX, infoY) {
var self = this;
var mLine = null;
var mHighlighted = false;
mLine = new com.ptvag.webcomponent.map.vector.Line();
mLine.setCoordinates(lineCoords);
self.addElement(mLine);
updateLine();
mHighlighted = true;
updateLine();
return true;
updateLine();
alert("Dropped on line");
updateLine();
var updateLine = function() {
if (mHighlighted) {
mLine.setColor("rgba(10,10,255,0.8)");
mLine.setPixelSize(12);
mLine.setPixelSize(10);
} else {
mLine.setColor("rgba(10,10,255,0.5)");
mInfoBox.setX(infoX);
mInfoBox.setY(infoY);
mInfoBox.setText("Line info");
mInfoBox = null;
updateLine();
return mLine.getSquareDistance(evt, 6).squareDistance;
// ==> adjust the tolerance (6) as needed
// overridden
qxp.OO.defineClass("custom.VectorLayer",
com.ptvag.webcomponent.map.layer.VectorLayer,
function(floaterLayer, isSecondary) {
com.ptvag.webcomponent.map.layer.VectorLayer.call(this, floaterLayer,
(isSecondary == null ? true : isSecondary));
var self = this;
var mapPackage = com.ptvag.webcomponent.map;
var vectorPackage = mapPackage.vector;
var CoordUtil = mapPackage.CoordUtil;
var EventUtils = com.ptvag.webcomponent.util.EventUtils;
var significantMovementDist = 9;
var significantMovementSquareDist =
significantMovementDist*significantMovementDist;
var mCurrentElement = null;
var mSelectableElements = {};
var mDropTargets = {};
var mDragElementStartPoint;
var mMouseStartPoint;
var mSignificantMovement;
var mDropTarget = null;
var resetSelection = function(elementToIgnore) {
for (var id in mSelectableElements) {
var element = mSelectableElements[id];
if (element != elementToIgnore) {
element.setSelected(false);
self.getSelection = function() {
var selectedElements = [];
if (element.getSelected()) {
selectedElements.push(element);
return selectedElements;
var superAddElement = self.addElement;
self.addElement = function(element) {
var id = superAddElement.apply(self, arguments);
if (element.getSelectable && element.getSelectable()) {
mSelectableElements[id] = element;
if (element.dragOver && element.dragOut && element.drop) {
mDropTargets[id] = element;
return id;
var superRemoveElement = self.removeElement;
self.removeElement = function(id) {
delete mSelectableElements[id];
delete mDropTargets[id];
superRemoveElement.apply(self, arguments);
var positionElement = function(element, position) {
var alreadyInBulkMode = self.inBulkMode();
if (!alreadyInBulkMode) {
self.startBulkMode();
element.setX(position.x);
element.setY(position.y);
element.setOpacity(mSignificantMovement ? 0.3 : 1);
self.endBulkMode();
var superOnMouseDown = self.onMouseDown;
self.onMouseDown = function(evt) {
if (mCurrentElement != null) {
// safeguard
if (mSignificantMovement) {
mSignificantMovement = false;
positionElement(mCurrentElement, mDragElementStartPoint);
if (mDropTarget != null) {
mDropTarget.dragOut(mCurrentElement);
mDropTarget = null;
mDropTarget = null;
if (!com.ptvag.webcomponent.util.EventUtils.isLeftMouseButton(evt)) {
return superOnMouseDown.apply(self, arguments);
mMouseStartPoint = {relMouseX:evt.relMouseX, relMouseY:evt.relMouseY};
var startPoint = self.getMap().translateMouseCoords(mMouseStartPoint);
var modifiers = EventUtils.getModifiers(evt);
var minDist = -1;
var squareDist = element.getSquareDistance(evt);
if (squareDist >= 0) {
if (minDist < 0 || squareDist < minDist) {
minDist = squareDist;
mCurrentElement = element;
if (modifiers & EventUtils.SHIFT_MASK) {
if (mCurrentElement.getSelected()) {
mCurrentElement.setSelected(false);
} else {
mCurrentElement.setSelected(true);
} else {
resetSelection(mCurrentElement);
if (self.hasEventListeners("selectionChanged")) {
self.createDispatchEvent("selectionChanged");
if (mCurrentElement.getDraggable && mCurrentElement.getDraggable()) {
mDragElementStartPoint = {x:mCurrentElement.getX(),
y:mCurrentElement.getY()};
self.getMap().getController().setActiveLayer(self);
return true;
var superOnMouseMove = self.onMouseMove;
self.onMouseMove = function(evt) {
if (mCurrentElement == null) {
return superOnMouseMove.apply(self, arguments);
var newPoint = self.getMap().translateMouseCoords(evt);
if (mCurrentElement != null &&
if (!mSignificantMovement) {
var distX = evt.relMouseX - mMouseStartPoint.relMouseX;
var distY = evt.relMouseY - mMouseStartPoint.relMouseY;
if (squareDist > significantMovementSquareDist) {
mSignificantMovement = true;
positionElement(mCurrentElement, newPoint);
var minDist = -1;
var newDropTarget = null;
for (var id in mDropTargets) {
var element = mDropTargets[id];
if (element == mCurrentElement) {
continue;
newDropTarget = element;
if (newDropTarget != mDropTarget) {
mDropTarget = null;
if (newDropTarget != null) {
if (newDropTarget.dragOver(mCurrentElement)) {
mDropTarget = newDropTarget;
return false;
var superOnMouseUp = self.onMouseUp;
self.onMouseUp = function(evt) {
return superOnMouseUp.apply(self, arguments);
mDropTarget.drop(mCurrentElement);
mDropTarget = null;
resetSelection();
self.getMap().getController().setActiveLayer(null);
return true;
var superOnMouseClick = self.onMouseClick;
self.onMouseClick = function(evt) {
resetSelection();
return superOnMouseClick.apply(self, arguments);
var superOnMouseOut = self.onMouseOut;
self.onMouseOut = function(evt) {
return superOnMouseOut.apply(self, arguments);
mDropTarget = null;
return false;
var superOnKeyDown = self.onKeyDown;
self.onKeyDown = function(evt) {
if (evt.keyCode != EventUtils.KEY_CODE_ESC ||
return superOnKeyDown.apply(self, arguments);
self.onMouseOut();
self.getMap().getController().ignoreNextClick();
// otherwise, a click event would be generated by the following
// mouse up
return true;
function init() {
var container =
document.getElementById("mapContainer");
var map =
new com.ptvag.webcomponent.map.Map(container);
map.setCenter({x:4303250, y:5486500});
map.setZoom(10);
var floaterLayer = map.getLayer("floater");
var vectorLayer = new custom.VectorLayer(
floaterLayer);
vectorLayer.setIsRelative(true);
map.addLayer(vectorLayer, "customVectorLayer", null, floaterLayer);
var element1 = new custom.IconElement();
element1.setX(4303326);
element1.setY(5486754);
element1.setSelectable(true);
element1.setDraggable(true);
vectorLayer.addElement(element1);
var element2 = new custom.IconElement();
element2.setX(4303250);
element2.setY(5486100);
element2.setSelectable(true);
element2.setDraggable(true);
vectorLayer.addElement(element2);
var lineCoords = [
4303326,5487054,4303352,5487084,4303376,5487101,
4303392,5487110,4303397,5487112,4303416,5487128,
4303443,5487162,4303455,5487177,4303464,5487185,
4303522,5487230,4303526,5487233,4303530,5487237,
4303533,5487240,4303539,5487246,4303580,5487287,
4303595,5487300,4303633,5487334,4303710,5487383,
4303727,5487398,4303748,5487416,4303772,5487438,
4303776,5487440,4303790,5487449,4303820,5487460,
4303840,5487467,4303948,5487499,4303958,5487502,
4303968,5487505,4303990,5487513,4304017,5487529,
4304024,5487536,4304030,5487544,4304076,5487606,
4304090,5487623,4304098,5487632,4304133,5487656,
4304158,5487670,4304165,5487674,4304284,5487726,
4304319,5487741,4304411,5487797,4304443,5487813,
4304492,5487848,4304509,5487862,4304529,5487874
var line = new custom.LineElement(lineCoords, 4303776, 5487440);
line.setSelectable(true);
vectorLayer.addElement(line);
qxp.dev.log.Logger.ROOT_LOGGER.setMinLevel(qxp.dev.log.Logger.LEVEL_INFO);
qxp.dev.log.Logger.getClassLogger(qxp.core.Init).setMinLevel(qxp.dev.log.Logger.LEVEL_ERROR);
</script>
</head>
<body onload="init()">
<div id="mapContainer"
style="position:absolute;left:0;top:0;right:0;bottom:0">
</div>
</body>
</html>Re: drag and drop (orders into a tour)
Hi Daniele,
Please have a look to this sample code too :
<html>
<head>
<!--[if IE]><script type="text/javascript" src="webcomponent/script/excanvas.js"></script><![endif]-->
// The default vector layer doesn't contain explicit support
// for drag-and-drop. So we define our own custom layer that
// allows elements to be dragged around.
// Static elements can still be added to the standard vector
// layer.
qxp.OO.defineClass("custom.DraggableElementsLayer",
var self = this;
var minMovementDist = 7;
// This is the minimum distance the mouse has to be
// dragged (to avoid recognizing simple clicks as
// drags).
var minMovementSquareDist =
minMovementDist*minMovementDist;
var tolerance = 14;
// This is the radius around the point where the
// element is placed within which a drag can be
// started.
var squareTolerance = tolerance*tolerance;
var mDragElement = null;
var mDragStartPoint;
var mStartPoint;
var mMinMovement;
var mDraggableElements = {};
mDraggableElements[id] = element;
return id;
var element = mDraggableElements[id];
if (element != null) {
delete mDraggableElements[id];
self.endBulkMode();
if (mDragElement != null) {
// safeguard
if (mMinMovement) {
positionElement(mDragElement, mDragStartPoint);
if (!EventUtils.isLeftMouseButton(evt)) {
mStartPoint = {relMouseX:evt.relMouseX, relMouseY:evt.relMouseY};
var startPoint = self.getMap().translateMouseCoords(mStartPoint);
var bounds = self.getMap().getRect();
var left = bounds.left;
var right = bounds.right;
var top = bounds.top;
var bottom = bounds.bottom;
var minDist = -1;
var visibleZoom = self.getMap().getVisibleZoom();
startPointPix = CoordUtil.smartUnit2Pixel(startPoint, visibleZoom);
for (var id in mDraggableElements) {
var x = element.getX();
var y = element.getY();
if (x < left || x > right || y < bottom || y > top) {
continue;
var pixPoint = CoordUtil.smartUnit2Pixel(
{x:x, y:y}, visibleZoom);
var distX = pixPoint.x - startPointPix.x;
var distY = pixPoint.y - startPointPix.y;
if (squareDist <= squareTolerance) {
mDragElement = element;
mMinMovement = false;
mDragStartPoint = {x:mDragElement.getX(),
y:mDragElement.getY()};
return true;
if (mDragElement == null) {
if (!mMinMovement) {
var distX = evt.relMouseX - mStartPoint.relMouseX;
var distY = evt.relMouseY - mStartPoint.relMouseY;
if (squareDist > minMovementSquareDist) {
mMinMovement = true;
if (mMinMovement) {
positionElement(mDragElement, newPoint);
return false;
if (mMinMovement) {
if (self.hasEventListeners("elementDropped")) {
self.createDispatchDataEvent("elementDropped",
{element:mDragElement, previousPosition:mDragStartPoint});
return true;
// Cancel the drag on mouse out
if (mMinMovement) {
return false;
// Cancel the drag when ESC is pressed
self.onMouseOut();
return true;
function init() {
var container =
var map =
// Add our new layer to the map
var dragLayer = new custom.DraggableElementsLayer(
floaterLayer);
dragLayer.setIsRelative(true);
map.addLayer(dragLayer, "drag", null, floaterLayer);
// Create an image (located in Karlsruhe) for testing
var image = new com.ptvag.webcomponent.map.vector.ImageMarker();
dragLayer.addElement(image);
// Do something when the element is dropped
dragLayer.addEventListener("elementDropped", function(evt) {
var element = evt.getData().element;
map.info("Element dropped at (smartunits): " +
element.getX() + "/" + element.getY());
</script>
</head>
<div id="mapContainer" style="width:100%;height:100%">
</div>
</body>
Dear All,
I never had the possibiliy to say thank you for your support, so, even if in late, Many thaks for your support.
Daniele
Daniele
