xRoute1 - Different responses for exact same request
huellif
Post by huellif »
we are using xRoute version 1.30.0.0 with map version EUR2021_2H.
This exact same SOAP-Request:
	<soap:Body>
		<ns4:calculateExtendedRoute xmlns:ns0="http://wrappertypes.service.jabba.ptvag.com"
                          			xmlns:ns1="http://common.xserver.ptvag.com"
                          			xmlns:ns3="http://xroute.xserver.ptvag.com"
                          			xmlns:ns4="http://types.xroute.xserver.ptvag.com"
                          			xmlns:ns2="http://baseservices.service.jabba.ptvag.com"
                          			xmlns:ns6="http://exception.core.jabba.ptvag.com">
			<ns4:ArrayOfWaypointDesc_1>
				<ns3:WaypointDesc fuzzyRadius="0"
                					linkType="AUTO_LINKING">
					<ns3:wrappedCoords>
						<ns1:Point>
							<ns1:point y="50.3203"
         								x="11.9244"/>
						</ns1:Point>
					</ns3:wrappedCoords>
					<ns3:wrappedSegmentID xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
                    						xsi:nil="true"/>
				</ns3:WaypointDesc>
					<ns3:wrappedCoords>
						<ns1:Point>
							<ns1:point y="52.51603"
         								x="13.37693"/>
						</ns1:Point>
                    						xsi:nil="true"/>
				</ns3:WaypointDesc>
			</ns4:ArrayOfWaypointDesc_1>
			<ns4:ArrayOfRoutingOption_2>
				<ns3:RoutingOption value="true"
                 					parameter="COUNTRY_ENCODING"/>
                 					parameter="ALLOW_SEGMENT_VIOLATIONS"/>
				<ns3:RoutingOption value="2500"
                 					parameter="COST_OF_SEGMENT_VIOLATIONS"/>
				<ns3:RoutingOption value="ISO2"
			</ns4:ArrayOfRoutingOption_2>
			<ns4:ArrayOfExceptionPath_3 xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
                          				xsi:nil="true"/>
			<ns4:ResultListOptions_4 featureDescriptions="true"
                       				totalRectangle="true"
                       				boundingRectanglesOffset="0"
                       				boundingRectanglesC="0"
                       				tollManoeuvres="false"
                       				manoeuvreGroups="false"
                       				urbanManoeuvres="false"
                       				brunnelManoeuvres="false"
                       				manoeuvreAttributes="false"
                       				segmentAttributes="true"
                       				segments="true"
                       				dynamicInfo="false"
                       				detailLevel="LESS_IMPORTANT"
                       				polygon="true"
                       				binaryPathDesc="false"
                       				nodes="true"
                       				texts="true"
                       				manoeuvres="true"/>
			<ns4:CountryInfoOptions_5 xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
                        				xsi:type="ns3:CountryInfoVehicleOptions"
                        				tollTotals="true"
                        				namedToll="true"
                        				calculatePartTollCosts="false"
                        				tollDate="2021-07-08T11:37:51.199+02:00"
                        				allEuro="true"
                        				detailedTollCosts="true">
				<ns3:wrappedOptions>
					<ns3:VehicleOption value="5"
                 						parameter="NUMBER_OF_AXLES"/>
					<ns3:VehicleOption value="TRU"
                 						parameter="TYPE"/>
					<ns3:VehicleOption value="40000"
                 						parameter="TOTAL_WEIGHT"/>
					<ns3:VehicleOption value="EURO_6"
                 						parameter="EMISSION_CLASS"/>
				</ns3:wrappedOptions>
			</ns4:CountryInfoOptions_5>
			<ns4:CallerContext_6>
				<ns2:wrappedProperties>
					<ns2:CallerContextProperty value="truckfast"
                         						key="Profile"/>
					<ns2:CallerContextProperty value="OG_GEODECIMAL"
                         						key="CoordFormat"/>
					<ns2:CallerContextProperty value="<Profile xmlns:xsi='http://www.w3.org/2001/XMLSchema-instance'>
    <Themes>
      <!--enable the PTV_TruckAttributes theme-->
      <Theme id='PTV_TruckAttributes' enabled='true'/>
    </Themes>
  </FeatureLayer>
  <Routing majorVersion='2' minorVersion='0'>
    <Course>
      <!--enable additional data rules to enable routing with additional content like feature layer-->
      <AdditionalDataRules enabled='true'>
      </AdditionalDataRules>    </Course>
    <Vehicle>      <Physical>        <Weight emptyWeight="2200.0" totalPermittedWeight="4000.0"/>        <Axle axleLoad="1800.0" numberOfAxles="5"/>        <Dimension height="250.0" length="1360.0" width="240.0"/>      </Physical>      <Legal>        <LegalCondition isDelivery="true"/>      </Legal>    </Vehicle>  </Routing>
</Profile>"
                         						key="ProfileXMLSnippet"/>
				</ns2:wrappedProperties>
			</ns4:CallerContext_6>
		</ns4:calculateExtendedRoute>
	</soap:Body>
</soap:Envelope>
is returning different answers:
a: 285,80 km toll for 53,49 Euro
or
b: 311,20 km toll for 0,0 Euro
The total way length always is 313,02 km and the route seems to be the same.
Can you tell me what's the problem?
I am sending the exact same request multiple times one after the other or at the exact same time, the results are random.
Best Regards,
Fabian
Re: xRoute1 - Different responses for exact same request
Hello Fabian,
afaik the task is in process as a regular support ticket now. Let's see what we can detect.
If the response is of public interest we can share it with the community.
huellif
Post by huellif »
If anyone else is facing this problem: Our toll data was broken, we mixed different and incompatible map and toll versions.
After cleaning up everything is working fine, thanks to the PTV support!
