Route calculation time
mnawias
Post by mnawias »
Calculate route with 6 waypoints takes 10 seconds. Is it normal time or we need to change something in server configuration or in sended request?
<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/">
   <s:Body xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
      <calculateRoute xmlns="http://xroute.xserver.ptvgroup.com">
         <request xmlns="">
            <requestProfile>
               <vehicleProfile driveType="MOTOR_VEHICLE">
                  <engine />
                  <weight />
                  <dimensions />
                  <legalCondition isDelivery="false" />
                  <load />
               </vehicleProfile>
               <featureLayerProfile>
                  <themes id="PTV_TruckAttributes" enabled="true" />
               </featureLayerProfile>
               <routingProfile>
                  <course distanceTimeWeighting="30" />
               </routingProfile>
            </requestProfile>
            <geometryOptions>
               <responseGeometryTypes>PLAIN</responseGeometryTypes>
            </geometryOptions>
            <waypoints xmlns:q1="http://xroute.xserver.ptvgroup.com" xsi:type="q1:OnRoadWaypoint">
               <location>
                  <coordinate x="19.265819599" y="50.358009298" />
               </location>
            </waypoints>
            <waypoints xmlns:q2="http://xroute.xserver.ptvgroup.com" xsi:type="q2:OnRoadWaypoint">
               <location>
                  <coordinate x="19.095579163" y="50.258018503" />
               </location>
            </waypoints>
            <waypoints xmlns:q3="http://xroute.xserver.ptvgroup.com" xsi:type="q3:OnRoadWaypoint">
               <location>
                  <coordinate x="20.731729497" y="52.375209841" />
               </location>
            </waypoints>
            <waypoints xmlns:q4="http://xroute.xserver.ptvgroup.com" xsi:type="q4:OnRoadWaypoint">
               <location>
                  <coordinate x="19.171760486" y="50.3043213" />
               </location>
            </waypoints>
            <waypoints xmlns:q5="http://xroute.xserver.ptvgroup.com" xsi:type="q5:OnRoadWaypoint">
               <location>
                  <coordinate x="18.695640604" y="50.276458731" />
               </location>
            </waypoints>
            <waypoints xmlns:q6="http://xroute.xserver.ptvgroup.com" xsi:type="q6:OnRoadWaypoint">
               <location>
                  <coordinate x="16.238300277" y="49.529289214" />
               </location>
            </waypoints>
            <routeOptions currency="PLN">
               <timeConsideration xmlns:q7="http://timeconsideration.xserver.ptvgroup.com" xsi:type="q7:ExactTimeConsiderationAtArrival" referenceTime="2021-05-11T10:15:58.6398915+02:00" />
               <polylineOptions elevations="true" />
               <tollOptions returnZeroCosts="true" />
               <monetaryCostOptions costPerKilometer="10" workingCostPerHour="40" />
            </routeOptions>
            <resultFields waypoints="true" nodes="true" polyline="true" monetaryCostsReport="true">
               <toll enabled="true" sections="true" systems="true" />
            </resultFields>
         </request>
      </calculateRoute>
   </s:Body>
</s:Envelope>
Re: Route calculation time
Hello Matheusz,
your routing requests a time consideration mode which has an impact on performance - at least for such a long total distance. So from this point of view I am not surprised.
Your request took me about 2 seconds on TEST and PROD (quite stable on all my 10 calls).
By adding PTV_TruckSpeedPatterns it took roughly 3seconds.
Did you test on a local environment?
PS: are the prices you used the final ones? Looks like they are not realistic
mnawias
Post by mnawias »
We add time consideration mode in request to get toll roads in Czech Republic. Is there another way to get toll roads in Czech Repeblic without time consideration mode? I tested it in an on premise system but i conntected via Internet.
PS: The prices we used are only for test.
Well, in fact the ExactAt-modes are the most precise ones and require more time than the others.
There's a less time consuming mode called SnapshotTimeConsideration which would return toll prices for countries such as Czech Republic.
I think you have to find the proper balance between quality and performance.
At least I didn't see a fundamental fault in your request.
PS: Do you need all the result field elements that you requested?
mnawias
Post by mnawias »
Hello Bernd
We changed Time Consideration Mode to mode called SnapshotTimeConsideration. Now calculate route with 6 waypoints takes 6 seconds.
         <request xmlns="">
            <requestProfile>
                  <engine />
                  <weight />
                  <dimensions />
                  <load />
               </vehicleProfile>
               <routingProfile>
               </routingProfile>
            </requestProfile>
            <geometryOptions>
            </geometryOptions>
               <location>
               </location>
            </waypoints>
               <location>
               </location>
            </waypoints>
               <location>
               </location>
            </waypoints>
               <location>
               </location>
            </waypoints>
               <location>
               </location>
            </waypoints>
               <location>
               </location>
            </waypoints>
               <timeConsideration xmlns:q7="http://timeconsideration.xserver.ptvgroup.com" xsi:type="q7:SnapshotTimeConsideration" referenceTime="2021-05-13T08:00:00+02:00" />
            </routeOptions>
            </resultFields>
         </request>
      </calculateRoute>
   </s:Body>
</s:Envelope>
OK, so there's improvement, though it is still slower than one would expect.
That's the price for quality ;-)
