I just started evaluating xServer 2 API, my tests just calculate a simple route between point A and B.
I am using the provided C# client code.
I first used the slightly easier synchronous calculateRoute method, a single http request is used to get the response.
I then started using asynchronous startCalculateRoute, now at least three http requests are used to get the response, the first to create a new job, the second to watch the job and the third to fetch the response.
If I only have a single RouteRequest with a simple route between A and B, the synchronous single call seems faster.
I understand that if the request becomes more complicated and takes longer to process on the xServer side, it makes more sense to use startCalculateRoute.
Also if I have many RouteRequests which I can fire off in parallel, the asynchronous way should work better.
So my question is are there any best practices for when to use calculateRoute vs. startCalculateRoute.
I think in our case it would be helpful to have something like startCalculateBulkRoute where I can pass in many RouteRequests and still only used 3 http requests (+ some Watch calls) even if I have hundreds of requests.
Peter Hahndorf
Senior Software Engineer
indiwa digitale kommunikation GmbH
Re: calculateRoute vs. startCalculateRoute
Hello Pete,
from my personal perspective the asynchronous approach is meaningful under specific conditions:
Furthermore: be aware that the AZURE load balancer disconnects you if a transaction exceeds a timeout of 3 minutes. So if you need that long the asynch is not only a convenient alternative but also the only way to successful response!
PS:
Please be aware htat "firing hundred requests in parallel" should not be done by design (part of the licensing statement's fair usage policy)
- If the transaction type is in fact complex enough to provoke a long calculation time (this happens with international routes of >1000km or if you apply specific settings such as PTV_SpeedPatterns in combination with TimeConsideration.ExactFromStart or ExactAtArrival).
- If there's a bulk implementation which enables you to get a status progress, e.g. in bulk geocoding where you can get "transaction(1234...) has already geocoded 50 out of 500 input addresses. You can build a progress bar and estimate also "end of process". This also works fine with distance matrices. (I hope we will offer a progress in tour optimization, too. This was already the case in xTour 1 / improvement phase)
- If you want to enable a user to interrupt a transaction (e.g. tour optimization) and consume the "best solution found so far".
- If you want to proceed in your client applications main thread till you get triggered for the "response available".
PS:
Hi Bernd, thank you for your reply.
In your PS you mentioned
I can not find these online, can you point me to the limits of API usage, e.g. requests per second?
I know this may depend on the kind of license we will use, but I like to know how hard I could hit the xServer internet.
Pete
Pete
Peter Hahndorf
Forwarded to Isabel - Product Management...
AFAIK there's a statement that you are supposed to send not more than 8 parallel requests but I prefer Isabel to handle this topic properly
Here's Isabel's statement:
translated:Hallo Bernd, vertraglich gibt es keine Begrenzung. Wir appellieren nur an uns auffällige Kunden sich an das von uns vorgeschlagene Limit von 8-10 parallele Requests zu halten.
Best regards,There's no contractual limitation. If the volume of a customer is eye-catching we recommend to them to send not more than 8-10 requests in parallel
