Impact of DistanceTimeWeight on routing
Posted: Fri Aug 21, 2020 2:49 pm
these days I was asked about the impact of the DistanceTimeWeighting parameter (xServer2 request routing profile, used to be OPTIMIZATION in xServer1). A user played with different settings of this parameter while he kept every other setting stable (waypoints, profile, speed values,...).
I created the following images with a test client - maybe this info also enlightens you about the normal behaviour: This is a regular behaviour but sometimes it requires an explanation or example to describe it
