Pre-release 1.7.6.0 - Version 1.7.6 available
Posted: Mon May 04, 2020 7:16 am
HI there,
Oliver released a new version Version 1.7.6 on git hub.
The NUGET packages have also been updated.
• Added LocalOffset property to reduce jitter of objects on deep zoom levels.
• Fixed propagation of XMapCredentials property for on-premise xServer.
This release has 3 assets:
• Binaries.zip
• Source code (zip)
• Source code (tar.gz)
Visit the release page to download them.
Thank you, Oliver!
Re: Pre-release 1.7.6.0 - Version 1.7.6 available
Posted: Tue May 05, 2020 11:16 am
by Oliver Heilig
a quick explanation of the LocalOffset parameter. When set for a (Shape-)Layer, shakiness of objects and rendering-artifacts (e.g. wrongly aligned hatches) can be eliminated for very deep zoom levels (> 18).
You can set it if your layer objects are confined to a specific region. At intialization just set it to the center of this region. An example in the DemoCenter:
https://github.com/ptv-logistics/xserve ... cs#L65-L74
Posted: Tue May 05, 2020 4:01 pm
by Oliver Heilig
OK,
i must admit the last post caused some annoyance. The effect of the LocalOffset-property is hard to visualize with static images. The problem only occurs for zoom levels which go beyond the maximum level supported by xMap itself (> 20).
I made a video which should clarify this
https://youtu.be/QiasKKUeVGk
