Route from vehicle points
krzysiek mbis
Post by krzysiek mbis »
I’ve a question from my customer (Transportation company).
Before Vehicle starts its tour (let say: with two points only), customer checks it on PTV. Then he knows how many km and what are the costs of this route.
After this tour, customer has a few thousand of geopoints in our database (these points are from our Telematic).
And he would like to set the route using this geopoints. The goal is to have it exactly the same (metre by metre) as vehicle did it.
The purpose is to have a real route costs.
And of course i know that a few thousand via points in one route is not a good idea, but can I do it somehow to beglad my customer needs?
Krzysiek Paziewski
Re: Route from vehicle points
Feeding thousand of point into xRoute is not a good idea. Not because the xRoute can;t handle them, but because due to GPS inaccuracy they probably sometimes are on a wrong road. Feed you point through xMapmatch first and then use the result to do the routing.
Do you only have the coordinates or by any chance also the time of recordig, heading and/or speed?
How often do you record a position from the vehicle?
Hello Kris,
as Joost already described: xRoute is used to calculate a route which will be driven in the future.
For those who collected GPS coordinates of a “historical” route we offer tha MapMatching module
There's a subforum dealing with this and Joost is a brilliant expert when it comes to MapMatching (and many other topics, too - by the way)
https://xserver.ptvgroup.com/forum/view ... ?f=8&t=763
https://xserver.ptvgroup.com/forum/view ... ?f=8&t=861
I strictly recommend to evaluate Joost's fabulous testclient, too
Currently our development team is designing the xMapMatch2 and I already saw some prototypes – looks fancy.
So if it is urgent : look at xMapMatch1
If you can wait for 2.18/2.19 : evaluate xMapMatch 2
I will also drag our MapMatching expert's attention to your post,
C u / Dzien dorbe,
krzysiek mbis
Joost wrote:Feeding thousand of point into xRoute is not a good idea. Not because the xRoute can;t handle them, but because due to GPS inaccuracy they probably sometimes are on a wrong road. Feed you point through xMapmatch first and then use the result to do the routing.
I have the coordinates and the time.
Krzysiek Paziewski
I would suggest xMapmatch profile wise you pick the sparse-signal as standard but do adjust the following values:
Mapmatching / Weights / @headingDifferenceRatingMinimum = 0
Mapmatching / Weights / @headingDifferenceRatingNormal= 0
Mapmatching / Weights / @headingDifferenceRatingMaximum= 0
Mapmatching / GeometricDeviations / @maximumHeadingDifference = 360
This to get around the fact that you do not have heading values. Alternative is that you calculate the heading yourself, but that only works well for really dense signals (you can test it for yourself but i usually only do this for 10 second intervals or shorter between measurements)
When sending input point do make sure you pick a speed value that is higher then Mapmatching / GeometricDeviations / @standstillDetectionSpeedThreshold . I would pick 18 for long routes, 12 for shorter routes (guestimates).
I recommend to continue this tuning discussion in the MapMatch forum ;-)
