Display TruckAttributes with Leaflet and OpenLayers
Post by Oliver Heilig »
here's short tutorial of how to add TruckAttributes layer to Leaflet and OpenLayers
Method 1: TruckAttributes via WMS
Demo OpenLayers: http://jsfiddle.net/oliverheilig/ea2kwcmf/
Demo Leaflet: http://ptv-logistics.github.io/Leaflet.NonTiledLayer/
The technique behind this approach is to add a new WMS Layer for TruckAttributes, so the layer can be switched ON/OFF independently. To achieve this, we have to add a new rendering profile to the xMap conf-directory and extend the WMS.properties file by a xmap-truckattributes layer. Here are the required files:
TruckAttributesConf.zip
(6.71 KiB) Downloaded 4470 times
You can query the truck attributes overlay with a WMS request then:
http://80.146.239.180/WMS/WMS?LAYERS=xm ... HEIGHT=643
xServer internet has these extensions already included, so you can also use this approach with xServer internet. Note: for "single-tile" WMS, Leaflet requires an addon we provide on GitHub: https://github.com/ptv-logistics/Leaflet.NonTiledLayer
Method 2: TruckAttributes via xMap/renderMap directly
The WMS response only contains an image, so you cannot implement some tooltip-interaction. We have a sample for adding TruckAttributes with tooltip information in Leaflet.
Demo Leaflet: http://ptv-logistics.github.io/Leaflet. ... ?layers=ta
Here the xServer is requested directly and the response contains the image plus object information. The object information is used to create clickable regions on the client. You can also apply this to your on-premise xServer installation, if you copy the attached rendering profiles.
Important: If you want to use the PTVLayer js-code with your xMapServer directly, you to have configure CORS at your .\webapps\xmap\WEB-INF\web.xml file and add the authorization and accept header:
	   <param-name>cors.supportedHeaders</param-name>
	   <param-value>Content-Type, origin, X-Requested-With, username, password, features, authorization, accept</param-value>
You can use this approach also with xServer internet, as it supports CORS for all xServers.
daxbin
Which license is required for displaying TruckAttributes via
Post by daxbin »
Hello Oliver,
I just tried to display TruckAttributes with OpenLayers via WMS (by the way, switching different styles classic, gravelpit, sandbox, silkysand as background maps and switching on/off labels as overlay layers works fine).
But when switching on the TruckAttributes layer there is nothing to see as if everything were transparent in this layer.
So I took a look into the logs and in the WMS.log I found there
2017-04-04 15:53:58,481;ERROR;com.ptvag.wms.layer.http.HttpComponentsBasedClient;http-bio-50010-exec-18;WMS ERROR: 500, Internal Server Error
2017-04-04 15:53:58,482;ERROR;com.ptvag.wms.layer.http.HttpComponentsBasedClient;http-bio-50010-exec-18;Unable to render map, RoadEditorLayer is not licensed. Please contact your vendor for a proper license.
What kind of license is missing to me because the xmap section of my license.ptv looks like this
xmap.maps=*
xmap.base=true
xmap.layers.poi=true
xmap.layers.trafficInfo=true
xmap.layers.RoadEditor=true
xmap.layers.rasterLayer=true
Best regards, Birk
Re: Display TruckAttributes with Leaflet and OpenLayers
Hello Birk,
sounds like a xMap issue. Please capture the native malicious request of xMap and provide it to us here: http://xserver.ptvgroup.com/forum/viewforum.php?f=5
With the rough info I can't answer your question.
sebastian.pietrzak
Post by sebastian.pietrzak »
Hello everyone,
im trying to run TruckAttributes on my xServer but i dont fully understand this description
https://xserver.ptvgroup.com/forum/down ... php?id=111
I just downloaded archive file with : truckattributes.ini, wms.properties and xmap-truckattributes.properties.
i have compared file xmap-truckattributes.properties from downloaded archive file with file which i have since installation xmap 1.24.0.1. I dont see any differences. This same is with file wms.properties and last file truckattributes.ini.
I trying run program https://github.com/ptv-logistics/Leaflet.PtvLayer with my server setup. But after when map show up i see only street without name and plus/minus. I dont see Tool-tip and any additional layer like TruckAttributes.
Its strange beacuse when i switch to your server all works fine. Where is problem ??
Hello Sebastian,
I delegated the topic to two colleagues (LNM, OH). OH is on vacation, LNM will take care of it. Maybe there is no 100% satisfying solution without a change of the used interface or framework. We'll see.
Hello Sebastian,
here's Oliver's response to your question. Does this answer it?
https://github.com/ptv-logistics/Leafle ... r/issues/1
Hello Sebastian,
here's Oliver's GITHUB response to your question. Does this answer it?
Hello Sebastian,
please read this:
https://xserver.ptvgroup.com/forum/view ... f=15&t=834
Oli
sebastian.pietrzak
Thank you for the quick reply.
I downloaded latest repo from github.Next i copied files from folder xmap-conf to my xMap Server/conf/
( i replaced all ).After all i rebooted service PTV xMap Server 1.24.0.1.
Without any change i opened index.file in Safari, Firefox, IE and Chrome with --allow-file-access-from-files.
Result is this same. I used your server.
I thought maybe there was problem with no token(line throw "NO TOKEN"; saw).
No problem i switched to my xMap server
In code changed :
var xMapUrl = 'https://xmap-' + cluster + '.cloud.ptvgroup.com';
to
var xMapUrl = 'https://myOwnxMap'; ( correct address i will send to Bernd, beacuse i know his email ).
comment line throw "NO TOKEN";
I see Tool-tip with checked additional layers. But i dont see any on the map.
Next i Checked lines with function getXMapBaseLayers and changed code line 126
var background = L.tileLayer('https://ajaxbg{s}-' + cluster + '.cloud.ptvgroup.com/WMS/GetTile/' +
to
var background = L.tileLayer('http://myOwnxMap/WMS/GetTile/' +
Now i have only problem with line 133. There is used token to xServer Internet. On my own installation i dont have token.
var foreground = new L.NonTiledLayer.WMS('https://ajaxfg-' + cluster + '.cloud.ptvgroup.com/WMS/WMS?xtok=' + token,
to
var foreground = new L.NonTiledLayer.WMS('http://myOwnXMap/WMS/WMS,
Result is better. I see street labels but TruckAttributes as i have not seen, i dont see further.
In the index.html set e.g.
        var xMapUrl = 'http://127.0.0.1:50010';
The samples should work with http://127.0.0.1:50010 and xtok = '''. I must admit i havent tested it for on-premise. A customer reported a similar issue for a sample i've fixed. https://github.com/ptv-logistics/xserve ... /xserver-1
What's important is that the Autorization Header is not set for on-premise. Theres a check, if the token is empty https://github.com/ptv-logistics/Leafle ... er.js#L197 To make sure you can just remove the line.
If it still doesn't work it should be a CORS configuration problem of your xServer. You should see an error in the console (F12 - something with cross origin). Maybe your xServer is not configured for CORS. It's in some file in the xServer Tomcat configuration. I cannot get my hand on an xServer installation now, so you have to wait till next week.
Oli
