xServer / SQL
Max Beermann
xServer / SQL
Post by Max Beermann »
Hello there,
I hope this is the right topic ;)
In Microsoft SQL Server Management Studio I have a database with a table that contains Geo-Coordinates (x/y).
Are there experiences / examples of how these coordinates can be enriched within SQL by using xServer (country, city, postcode)?
For example by using a procedure?
Thanks a lot for any feedback :)
Max Beermann
Max Beermann
Development Manager
WHEELS Logistics
Re: xServer / SQL
Hello Max,
I have no experience doing this directly in SQL server. All the software designs i have encountered always do this in middle ware since it usually has more powerful tools for handling web connections.
With regards,
Re: xServer / SQL
Hello Max,
I once did this in the early 2000nds. Have no source to provide.
Worked within a trigger so each
- insert
- update on address columns
Was used to perform a call to the geocoding interface.
Honestly spoken this was more a nice experiment than a real need. Therefore I agree with Joost: use the DB as a storage and an application layer to provide a frontend.
Best regards from Austria
Ps we implemented a user defined function in T-SQL which created clients through a DLL. This shows how old school this approach is.
Max Beermann
Re: xServer / SQL
Hey there,
thanks for your feedback!
I will keep you informed, in case I have a solution / a need ;)
Best regards (to Austria, Germany, anywhere in the world)
Max
Max Beermann
Development Manager
WHEELS Logistics
