cannot calculate route (concerning leg 1)
i.kobeissy
Post by i.kobeissy »
hello,
i'm trying to use caculateRoute on xRoute server, i'm using the version 1.24, and 2016 maps
my request is very simple it's just 2 waypoints, and always getting "cannot calculate route"
now here's how i'm thinking, if i'm doing anything wrong please tell me or tell me where i should be looking
- in the attached request file, i'm able to draw the 2 waypoints on the map
- the coordinates of the two waypoints are calculated using xLocate
==> so with these 2 facts in hand i can assume this is enough to say that the coordinates are correct
- out of these 2 waypoints i was able to create a tour using xTour and now i'm trying to draw the tour,
==> and this is what's not logical for me
xTour is able to create a tour but xRoute is not able to calculate the route, and also attached the response i'm getting, it's always stating cause nil
can anyone help me with this please
response.xml
(1.04 KiB) Downloaded 416 times
request3.xml
(2.21 KiB) Downloaded 415 times
Re: cannot calculate route (concerning leg 1)
Hello Ibrahim,
looks like the start waypoint causes an issue:
as you didn't specify the LinkingType property the engine applies the default value which is a NEXT_NODE.
By setting it to an explizit AUTO_LINKING it works on my local environment.
Please check this...
PS: sorry for the late reply - I've overseen your post's notification mail
