xServer 2 - Swiss toll missing
Andreas Schönebeck
Re: xServer 2 - Swiss toll missing
Post by Andreas Schönebeck »
Here the exact request produced by our software:
With toll returned:
  "$type":"RouteRequest",
  "waypoints":[
      "$type":"OffRoadWaypoint",
      "location":{
        "$type":"OffRoadRouteLocation",
        "offRoadCoordinate":{
          "x":7.4404602694,
          "y":46.948429118
      "tourStopOptions":{
        "serviceTime":0.0
      "name":"0"
      "location":{
          "x":7.3207202102,
          "y":45.7375107
      "tourStopOptions":{
        "serviceTime":0.0
      "name":"1"
  "routeOptions":{
    "timeConsideration":{
      "$type":"ExactTimeConsiderationAtStart",
      "referenceTime":"2021-11-30T00:00:00+01:00"
    "geographicRestrictions":{
      "allowedCountries":[
      "prohibitedCountries":[
    "emissionOptions":{
      "valueScenarios":[
          "$type":"EmissionValueScenario_HBEFA_3_2",
          "scenarios":[
            "CURRENT_ROUTE"
    "currency":"EUR"
  "resultFields":{
    "waypoints":true,
    "legs":{
      "enabled":true
    "segments":{
      "enabled":true,
      "descriptors":true,
      "roadAttributes":true,
      "id":true
    "eventTypes":[
      "COUNTRY_EVENT",
      "TOLL_EVENT",
      "ROUTE_VIOLATION_EVENT"
    "polyline":true,
    "toll":{
      "enabled":true,
      "sections":true,
      "systems":true
    "emissions":true,
    "encodedPath":true
  "requestProfile":{
    "vehicleProfile":{
      "engine":{
        "cylinderCapacity":1500,
        "fuelType":"GASOLINE",
        "fuelConsumption":6.0,
        "particleFilterInstalled":false,
        "emissionStandardEU":"EURO_6",
        "lowEmissionZoneTypes":"DE_GREEN"
      "weight":{
        "emptyWeight":1200.0,
        "loadWeight":200.0,
        "totalPermittedWeight":2000.0
      "dimensions":{
        "height":160.0,
        "heightAboveFrontAxle":100.0,
        "length":425.0,
        "width":175.0
      "axle":{
        "axleLoad":11500.0,
        "numberOfAxles":5
      "legalCondition":{
        "isEmergency":false,
        "isDelivery":false
      "load":{
        "loadType":"PASSENGER"
      "speeds":{
        "speedRangesByNetworkClass":{
          "maximumSpeeds":[
            135.0,
            125.0,
            85.0,
            60.0,
            50.0,
            40.0,
            16.0,
            6.0
          "minimumSpeeds":[
            70.0,
            35.0,
            25.0,
            25.0,
            20.0,
            18.0,
            9.0,
            4.0
        "maximumSpeed":150.0
      "yearOfManufacture":2019,
      "numberOfPassengers":2,
      "numberOfTrailers":0
    "featureLayerProfile":{
      "themes":[
          "id":"PTV_TruckAttributes",
          "enabled":false
          "id":"PTV_TruckSpeedPatterns",
          "enabled":false
          "id":"PTV_TrafficIncidents",
          "enabled":false
    "routingProfile":{
      "linking":{
        "maximumDistanceToSegment":10000.0
      "course":{
        "violations":{
          "enabled":true
        "network":{
        "toll":{
        "specialAreas":{
        "combinedTransport":{
          "boatPenalty":0,
          "railPenalty":0
        "distanceTimeWeighting":90.0
  "coordinateFormat":"EPSG:4326"
Without toll returned:
  "waypoints":[
      "location":{
          "x":7.4404602694,
          "y":46.948429118
      "tourStopOptions":{
        "serviceTime":0.0
      "name":"0"
      "location":{
          "x":7.3207202102,
          "y":45.7375107
      "tourStopOptions":{
        "serviceTime":0.0
      "name":"1"
  "routeOptions":{
    "emissionOptions":{
      "valueScenarios":[
          "scenarios":[
            "CURRENT_ROUTE"
    "currency":"EUR"
  "resultFields":{
    "waypoints":true,
    "legs":{
      "enabled":true
    "segments":{
      "enabled":true,
      "descriptors":true,
      "id":true
    "eventTypes":[
      "COUNTRY_EVENT",
      "TOLL_EVENT",
    "polyline":true,
    "toll":{
      "enabled":true,
      "sections":true,
      "systems":true
    "emissions":true,
    "encodedPath":true
  "requestProfile":{
    "vehicleProfile":{
      "engine":{
      "weight":{
        "loadWeight":200.0,
      "dimensions":{
        "height":160.0,
        "length":425.0,
        "width":175.0
      "axle":{
        "axleLoad":11500.0,
        "numberOfAxles":5
      "legalCondition":{
        "isDelivery":false
      "load":{
      "speeds":{
          "maximumSpeeds":[
            135.0,
            125.0,
            85.0,
            60.0,
            50.0,
            40.0,
            16.0,
            6.0
          "minimumSpeeds":[
            70.0,
            35.0,
            25.0,
            25.0,
            20.0,
            18.0,
            9.0,
            4.0
      "themes":[
          "enabled":true
          "enabled":false
          "enabled":false
    "routingProfile":{
      "linking":{
      "course":{
        "violations":{
          "enabled":true
        "network":{
        "toll":{
        "specialAreas":{
          "boatPenalty":0,
          "railPenalty":0
I checked with a diff tool, that only the one single line "enabled":false / "enabled":true is different between requests. I hope you can help us with this. And thank you very much indeed for your help so far.
Andreas Schönebeck
Another remark. If truck attributes are enabled (second request in previous post), the route does not go through St Bernard Tunnel and therefore no toll is calculated:
Your axle load is to high. it is set to 11500 and there is a 8000 axle load blocking on the route that goes through the tunnel. Note: although it does not influence this particular route you also have to many axles (5 atm). I would recommend not writing out the entire request profile and just set the storedProfile to "car" in this case.
Andreas Schönebeck
Many, many thanks for the great help. The axle load was indeed the problem.
