can you please advise on where to set preferred types of roads in vehicles profile for calculating a route ( xRoute.calculateExtendedRoute).
Thank you,
Vladimír
Preferred types of roads in vehicle profile
Vladimír Plachý, DiS.
Re: Preferred types of roads in vehicle profile
Hello Vladimir,
please check this section describing the profiles:
http://xserver.ptvgroup.com/fileadmin/f ... g%7C_____0
Here is a minimalistic snippet
It's not using highways (NC_0 and NC_1 are set to 2501) and doesn't matter to use NC_2..NC_7)
Attention:
Blocking "toll roads" isn't based on Network Class - check this:
http://xserver.ptvgroup.com/fileadmin/f ... Rules_Toll
Furthermore Ferries, Piggyback and MountainPasses have their own settings..
<Profile>
<Course>
<BasicDataRules>
<Network rampMalus="10">
<MalusByNetworkClass malus="2501"/>
<MalusByNetworkClass malus="0"/>
</Network>
</BasicDataRules>
</Course>
</Routing>
</Profile>
Side note: in the next version of map and guide internet you can directly export your vehicle to a usable XML profile for xRoute.
Motorways is NC_0 and Fast Route is NC_1? And what about those other values NC_x?
Hello Vlad,
I have limited access at the moment.
Check the data type NetworkClass in the standard API doc. The enum starts with highways and ends up somewhere at "pedestrians and cycle lanes".
