Minimum result size for geocoding
Benjaminabat
Post by Benjaminabat »
For reverse geocoding there is an option to set ENGINE_MINSIZE to an integer value. The returned result must be at least as big. Is there a similar option for "normal" geocoding?
Re: Minimum result size for geocoding
I don't think that there is such a option. But I also do not understand the use case behind this. What do you expect such an option would do for example if you enter a completely valid addres including house number? Then there is only 1 valid option to return in my opinion.
Benjaminabat
My use case would be to always have at least one result returned. Thus the entered address could be returned.
Hello Benjamin,
if you provide an invalid address such as
Country = GER
City = Munich
Street = SCHNICKSCHNACK (which doesn't exist)
our algorithms try to identify alternative addresses and cut the result (GER Munich, Schnickstraße).
If there are no alternatives found on street level we escalate to a more surficial level such as "GER Munich" and so on.
The strategy here is - as Joost already explained - return something if it is meaningful but not in any case.
Compared to SQL:
If you request a SELECT TOP 1 * FROM TheMagicTableWithBillionsOfDatarecords WHERE ImpossibleCondition you will get an empty result set though you specify the TOP statement.
