| Api | VarVersion | Type | Date | Description |
| Route Optimization API | 1.39.0 | FEATURE | 19.01.2026 | Optimization result metadata now includes both started and finished timestamps for improved traceability of optimizations. |
| Route Optimization API | 1.39.0 | FEATURE | 19.01.2026 | Added updateMetadata endpoint to update the metadata of an optimization. |
| Route Optimization API | 1.39.0 | FEATURE | 19.01.2026 | Added deletion time to metadata which allows specifying the desired deletion time of an optimization. |
| Route Optimization API | 1.39.0 | IMPROVEMENT | 19.01.2026 | Wait time is now treated as work time with regards to breaks. As a consequence, breaks at a stop may also occur during waiting periods, making this field relevant in non-electric vehicle scenarios. |
Route Optimization API - Api Changes 1.39.0 (19.01.2026)
Re: Route Optimization API - Api Changes 1.39.0 (19.01.2026)
Route Optimization API OpenAPI Update Analysis (v1.38 → v1.39)
This post summarizes the structural changes between the OpenAPI specifications
v1.38 and v1.39.
The focus is on schema / model changes that are relevant for client integrations.
1) Endpoints / Paths
No changes
There are no new, removed, or modified endpoints between v1.38 and v1.39.
All existing routes remain unchanged, including:
This release does not affect routing, URLs, or HTTP semantics.
2) Component Schemas
No new schemas introduced
No new object types were added at schema level.
3) Existing Schemas – Structural Changes
Result: No structural schema changes detected
A detailed comparison of the component schemas shows:
The schema structure is identical between v1.38 and v1.39.
4) Cost-related Models
All cost-related schemas (including route-level and result-level costs):
There are no changes in cost modeling between these versions.
5) Required / Optional Semantics
There are:
From a validation and deserialization perspective, v1.39 behaves exactly like v1.38.
6) Client Impact / Compatibility Notes
Fully backward compatible
v1.39 is a non-breaking, no-impact update for client integrations.
7) Summary
PTV OptiFlow OpenAPI v1.39 introduces no structural changes compared to v1.38.
From an API consumer perspective, v1.39 is effectively equivalent to v1.38.
Final note
v1.38 and v1.39.
- /optimizations
- /optimizations/{id}
- /optimizations/{id}/progress
- /optimizations/{id}/metadata
- /optimizations/{id}/request
- /optimizations/{id}/stop
- All component schemas present in v1.39 already existed in v1.38.
- No new properties added to existing schemas
- No properties removed
- No changes to required/optional semantics
- No type changes
- remain unchanged
- have the same structure and semantics as in v1.38
There are:
- no new required fields
- no changes to existing required definitions
- no changes regarding nullable vs. non-nullable fields
- No DTO changes required
- No regeneration strictly necessary for structural reasons
- Existing clients built against v1.38 will continue to work unchanged
7) Summary
- No endpoint changes
- No schema changes
- No cost model changes
- No required/optional changes
- Fully backward compatible
Final note
- This comparison is strictly based on OpenAPI structure.
Behavioral changes (e.g. different result values or optimization logic) cannot be inferred from the specification alone.
