I have a question for the xTour endpoint of xServer 2.
1 Depot: Holzkirchen
3 Customers:
- Amstetten
1x order 4773 kg
- Esslingen
1x order 3008
- Pforzheim
48x orders 822 kg
The total quantity of the truck is defined with 24000 kg, 3 trucks are available.
Customer stops per tour is definied with max. 2.
Single trip per tour, single depot per tour as well as minimize number of tours is enabled.
I am using direct distance in this example to provide a smaller sample set.
What I am expecting is that the algorithm creates 2 trips, like this:
Tour 1:
- Amstetten 4773 kg
- Pforzheim 19227kg
Tour 2:
- Esslingen 3008 kg
- Pforzheim 20229 kg
Unfortunately, there are always 3 trips created. The first trip is a FTL with 23838 kg of Pforzheim and then two other trips.
Please see attached the json files "request1_3 vehicles.txt" and "response1.txt"
What I tried
Setting the maximum number of vehicles to 2 to force my expected behavior.
But now one order remains unplanned.
Please see attached "request2_2 vehicles.txt" and "response2.txt"
Is there something that I am missing in the request?
Minimize number of tours PTV xServer 2 - xTour
- Attachments
- request1_3 vehicles.txt
- Request 1 - 3 vehicles
- (10.98 KiB) Downloaded 1996 times
- response1.txt
- Response 1
- (50.78 KiB) Downloaded 2046 times
- request2_2 vehicles.txt
- Request 2 - 2 vehicles
- (10.96 KiB) Downloaded 1916 times
- response2.txt
- Response 2
- (37.98 KiB) Downloaded 2007 times
Re: Minimize number of tours PTV xServer 2 - xTour
Checked this with Daniela: you did run into a weakness of the heuristics:
