Java Sample not working
egeschwinde
Post by egeschwinde »
I'm evaluating the PTV Xserver Internet and I found following Code Sample on this link
http://xserver.ptvgroup.com/dk/cookbook ... d-classes/
I generate with mvn and it generates me a jar file.
The problem what I have is when I try to use the test class the classes
import com.ptvag.jabba.service.baseservices.ArrayOfCallerContextProperty;
import com.ptvag.jabba.service.baseservices.CallerContext;
import com.ptvag.jabba.service.baseservices.CallerContextProperty;
import com.ptvag.xserver.common.ArrayOfPoint;
import com.ptvag.xserver.common.PlainPoint;
import com.ptvag.xserver.common.Point;
import com.ptvag.xserver.xroute.ArrayOfWaypointDesc;
import com.ptvag.xserver.xroute.LinkType;
import com.ptvag.xserver.xroute.ResultListOptions;
import com.ptvag.xserver.xroute.Route;
import com.ptvag.xserver.xroute.WaypointDesc;
import com.ptvag.xserver.xroute.jwsdp.XRouteWS;
Are invalid and missing - from my view it should generate the WSDL with maven or am i missing something here (another Jar maybe) ?
Ewald Geschwinde
Oliver Heilig
Re: Java Sample not working
Post by Oliver Heilig »
Hello Ewald,
we have a more detailed guide for generating java clients from WSDL here:
http://devblog.ptvgroup.com/2013/01/23/ ... -xservers/
It describes the practices with a local xServer, but it should also work with xServer intenet if you replace the url by https://xroute-eu-n-test.cloud.ptvgroup ... Route?WSDL
Unlike C#, generating Java classes from a WSDL is generally a bit cumbersome, so we recommend using the Java client classes that can be downloaded. Se here for a tutorial:
http://xserver.ptvgroup.com/de/cookbook ... lications/
Oliver
Not sure whether our samples cover "retrieving the WSDL with authentification"... anyhow: you should be able
  • to download the WSDL file using your token
  • store it locally
  • create the clients on a local basis
Usually the URLs of the services are part of the applications later configuration e.g. because you develop with TEST url and redirect the application for PRODUCTION afterwards.
