Hi Oliver,
one of my partners is cleaning up his xServer.NET driven projects. Looks liek some files are not located properly after an update:
In the pastThese files have been located in the programm folder AND in the subfolder DE.
Where should they be located from now on?
resources... where to drop them?
- Oliver Heilig
Re: resources... where to drop them?
Here the the list of the assemblies contained in the binarie zip or nuget package.
The .pdb and .xml files contain information for debugging and api-documentation.
| de/Ptv.XServer.Controls.Map.resources.dll | Satellite assembly containing localized texts in german. For example: This will display "Kartenebenen" instead of "Layers" in the layers list when running on a german Windows. If the DLL is missing the default (english) texts are used. |
| Ptv.Components.Projections.dll | This assembly contains the components for reprojection with PROJ.4. It should only be required when using specific coordinate systems. |
| Ptv.XServer.Controls.Map.dll | The map control. |
| Ptv.XServer.Controls.Map.XmlSerializers.dll | This assembly contains pre-compiled code for SOAP/XML, used by the xMap-1 access. If it is not present, this code is created at runtime. |
Oliver Heilig
PTV GROUP - Germany
PTV GROUP - Germany
