We are trying to get data from PTV using curl from our Linux server.
The request itself we test at the raw request runner and put in a file  "/..../PTV_TEST4.TXT"
If we test with the command:
curl -X GET -H 'Authorization: username xtok' -H 'Authorization: password *token*' -H 'Content-Type: application/soap+xml;charset=utf-8' --data-binary @ '/........../PTV_TEST4.TXT'  'https://xserver2-europe-eu-test.cloud.p ... /ws/XRoute'
The respons is:  curl: (3) <url> malformed
So there must be a small syntax problem in my command.
Can someone help me with the correct command to use with curl?
Thanks in Advance.
Greetings
Koos
						Using curl for communications
Re: Using curl for communications
I'm not experienced with using curl, but going from the manual the command should be:
Only thing I'm not sure about is if I specify the file location correctly
curl-X POST -u xtok:<TOKEN> -H 'Content-Type: application/soap+xml;charset=utf-8' --data-binary @ '/........../PTV_TEST4.TXT' https://xserver2-europe-eu-test.cloud.ptvgroup.com/services/ws/XRouteJoost Claessen
				koos@hsf.nl
Thank you, the -u did the trick. Now i get more respons and can continue.
