Engine error: Invalid partner stop tour position (code: -106
ptvs-ff
Post by ptvs-ff »
Hallo liebes Supportteam,
Bei folgendem Request erhalten wir sowohl auf dem Test als auch auf dem Prod xTour Server einen Engine error. Seht Ihr einen Grund, weshalb?
Engine error: Invalid partner stop tour position (code: -1063)
Request.xml
(14.78 KiB) Downloaded 587 times
Response.xml
(1.24 KiB) Downloaded 609 times
when in danger or in doubt, run in circles, scream and shout!
Re: Engine error: Invalid partner stop tour position (code:
Your delivery locations, TransportPointB of the orders, require tourSection 1. The value of 1 is special that there can only be a single toursection1 location in a tour and it must be the the first location in the tour.
To translate this into more human term: your request requires that your deliveries are the first thing that will be done, even before the pickup. This cannot be and thus xTour throws an exception.
ptvs-ff
Post by ptvs-ff »
Ah, a classical case of RTFM. Here's the appropriate documentation for this, for those that come after me: https://xtour-eu-n.cloud.ptvgroup.com/m ... ourSection
Transport points with tourSection 0 will be placed anywhere. TourSection 1 will be the first stop within a tour, and 1000 will be the last stop. There will be not more than one transport points within a tour with tourSection 1 or 1000, respectively.
Thanks for the help, Joost!
