Memory Dump files
KZsolt
Memory Dump files
Post by KZsolt »
Helo guys!
Could you please tell me how am I suppose to disable the creation of memory dump files in the server enviroment?
I've tried to add the -XX:-CreateMinidumpOnCrash parameter to the module runner, the whole command looks like this:
moduleRunCmd={cbd}/jre/bin/xroutemodule.exe -Xms32M -Xmx128M -Xss8M -XX:ErrorFile={cbd}/logs/hs_err_pid%p.log -cp {cp} -Dxmoduleinstance={suf}{###} -Dcatalina.base={cbd} -Djava.library.path={lib} {cls} {suf} {prt} -XX:-CreateMinidumpOnCrash
But after that fix the service automatically shuts down after the startup.
Do I need to make any other configuration?
Thank you,
Zsolt
Mathias.Heß
Re: Memory Dump files
Post by Mathias.Heß »
Hello Zsolt,
adding -XX:-CreateMinidumpOnCrash works fine since our current xServer releases are shipped with this option. However you cannot add the option to the end of the property value, then the xServer framework fails to interpret the command line value correctly.
moduleRunCmd={cbd}/jre/bin/xroutemodule.exe -Xms32M -Xmx128M -Xss8M -XX:ErrorFile={cbd}/logs/hs_err_pid%p.log -XX:-CreateMinidumpOnCrash -cp {cp} -Dxmoduleinstance={suf}{###} -Dcatalina.base={cbd} -Djava.library.path={lib} {cls} {suf} {prt}
should work fine.
Mathias Heß
KZsolt
Post by KZsolt »
Helo!
Thank you for the comment, that fixed config seems to worK!
K. Zsolt
