Routing not possible in both directions
Sebastian.Simon
Post by Sebastian.Simon »
i`ve a strange topic (and problem) about a routing, which is possible in one direction, but impossible in the opposite way.
i added both xml-requests and would be happy, if you are able to give me a hint (or a solution) how to enable both ways.
Thanks!
routing_wrong.xml
routing doesn`t work
(2.4 KiB) Downloaded 535 times
routing_correct.xml
routing works
(2.39 KiB) Downloaded 562 times
Re: Routing not possible in both directions
Hello Sebastian,
both requests work fine on https://xroute-eu-n-test.cloud.ptvgroup.com (EU City map TOMTOM 2019.1).
Did you use a local installation?
Or the cloud? If cloud: which service URL?
Sebastian.Simon
sorry for the inconvenience, i did a mistake.
We are excluding some countries from routing and Russia was one of this countries.
I removed Russia, routing is possible for both directions..
Sebastian
