Dear xServer Stakeholders,
the PTV xServer 2.12 is released! The highlights are:
o General (Admin): Separated Java installation obligatory (64-bit, Java 8, Amazon Corretto or Oracle Java) (see here)
o General (Admin): Stored profiles with data compatibility version 2 (suitable for recent PTV maps) (see here)
o xLoad: Unloading sequence of items and stacking restrictions between item types (experimental)
o xLocate: Different country representations (e.g. ISO 3166-1 or license plate code)
o xLocate: Reverse geocoding ready for productive usage (i.e. no longer experimental)
o xRoute: New REST-API for route calculation (experimental)
o xTour: Planning of precombined trips (experimental)
The on-premise solution can be found here:
o Developer Zone: https://www.ptvgroup.com/en/solutions/p ... version-2/ (login required)
Regards, your xServer 2 teams
xServer 2.12 released
Re: xServer 2.12 released
HI Bernd,
you are cheating!
Following the link, I only found 2.11 xServer 2 released in February. All other things, like profiles etc., have release date 26th of April.
What's going on?
you are cheating!
What's going on?
Mr. X
- Integration PTV <> SAP
- Senior Consultant
2.12.0 is again available at the Customer Area
Sorry for the inconvenience...
