Dear,
is there a way in xTour2 to force the engine to plan the pickups preferably more to the end of the tour?
Because in pallet distribution if you do a pickup in the beginning of the tour, you have to move the collected pallets the whole day to unload the rest, because you can only load/unload from the back of the truck and the collected pallets are in front of the pallets for delivery.
In xTour1 I could force this by setting maxTransportPeriod on the collection orders, based on the number of pallets I could restrict the transit time so the engine had to plan them more to the end. Putting 1 pallet out of the way is less of a problem then moving 5 on each stop.
Pickup's more to the end of the tour (xTour2)
peter.gheeraert
Best Regards,
Peter
Best Regards,
Peter
Re: Pickup's more to the end of the tour (xTour2)
Hello Peter,
currently I don't see any dedicated parameter for this usecase. But my thoughts are
PS: what did Joost recommend?
- In xTour 1 we recommended to use the tourSection to enforce pickups being positioned at the end of tours (anyway: I like the way you approached it)
- Another xPlayer asked something similar few days ago and we mentioned to define a reduced quantity (e.g. 27 palettes instead of 33). This will ensure that there's always some space to move between the palettes.
confirmed by DEV:
requires TourSection which isn't available so far (FEB 2019)
peter.gheeraert
Bernd,
thanks for the answer. I'm migrating to xTour2, I'll shedule a meeting with Joost in the coming weeks after we have done some more tests with actual data.
Reducing the quantities is a solution, but this also has an efficiency impact on the trips without pickup orders. For now I will let the engine plan freely and have the planners if needed re-plan the pickups by using the MoveOrdersAction with InsertionAfterSpecifiedPosition.
Best Regards,
Peter
Best Regards,
Peter
